4.10 gears question
KBExperience
466
Houston
I bought some ford racing 4.10 gears at american muscle this week and i was wondering what all i needed to do to get them installed?
Since my stang is an auto, do i need to get the shift points calibrated?
Can i use a tuner that calibrates the speedo to calibrate the shift points?
what kind of tuner should i buy?
Just buy the gears and install kit and have them installed. Yea you'll need the speedo re-caled. For a tuner most go with the SCT stuff. I like Sniper. Your shift points wont NEED to be messed with but if your getting a tuner then you might as well get a custom tune. With a custom tune your shift points may be altered.
You dont need to get the shift points reset. Hell, I'd buy a shift kit to do that (a shift kit recalibrates shift points and enables much firmer/harder shifts). Yes, your speedo will be off but it will be very minimal (maybe 2-3mph). American Muscle sell a speed calibrator but for some reason, they list it as being for 99-04 MANUALS and 96-98 AUTO'S ONLY (dont know why).
Are you planning to install them yourself or have a transmission shop do it?
No to hijack the thread, but I am in the same boat. My 4.10s are waiting to be installed...does anyone recommend the carbon clutch rebuild kit for the rear? I only have 80K miles and I am just wondering if the rear needs to be rebulit
Do a short burnout and check out the marks left buy the tires. See how well its locking up - i.e. is one tire weak or missing a mark altogether.
I'd get mine done and I've only got 50k on it. I'm certainly no expert tho so lets wait for others to chime in.
You need to fix your speedo so you may as well get a tuner that will also give you a nice gain and better shifting. XCAL3 is probably the way to go because it'll hold dyno tunes from any SCT shop in the future.
BTW Mine did not shift right without the chip, it was very late.
Who you buy from makes a difference if you get a custom tune. Someone like modular depot would be a good choice.
The difference the gears and chip/tuner make to the auto is amazing. You are going to LOVE IT. Congrats.
