4:10 Gears?
  • Thread starter Thread starter Paul Randle
  • Start date Start date Oct 3, 2012
Paul Randle
87
orlando
Oct 3, 2012
  • Oct 3, 2012
So i have 3:55 gears now if i switched to 4:10 gears would just switching gears give me a quicker quarter mile time? someone told me i would cut off a half second. Is that true?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Oct 3, 2012
  • Oct 3, 2012
A half second is really generous. With your mods and current gear set you'll likely pick up .1-.2-tenths to be frank....and that's assuming you're able to put the power to the pavement. Remember, with 4.10's it's going to be harder to control wheel spin. Your mileage is really going to take a nose dive too.
If you drive this car primarily on the street, I'd advise against the 4.10's. Some guys will tell you otherwise, but my own personal prefference is less gear, not more. If you used this car more at the track and were going from the stock 2.73's, then I'd say consider it, but you've already got 3.55's. The benefit doesn't out weight the cost IMO. If it were me, I'd concentrate on adding more power instead of more gear.
See what you think after your GT40 install. The additional power may be enough that you won't feel gears necessary anymore. That being said...if you've got enough money to swap your gears, then you might be better off sinking it into a better set of heads instead of the iron GT40's you've got. Just food for thought.
Reactions: Paul Randle
Paul Randle
87
orlando
Oct 3, 2012
  • Oct 3, 2012
okay cool yeah i will just keep the gears i have lol. I am going to get the explorer upper and lower intake and the heads with upgraded valve springs, and a 65mm throttle body and see what the track difference is. I am running 14.2 right now with the street tires.
thank you
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,147
2,779
224
Vass, NC
Oct 3, 2012
  • Oct 3, 2012
I swapped from 3.55s to 4.10s in an older project of mine. I changed so many other things that the drop in quarter mile times cannot be attributed to anything in particular, though. I went from 13.5s to a best of 11.96, but I also picked up 50 rwhp at the same time.
That said, I believe that with sticky tires, you would see a very nice improvement in your 1/4 mile times, but probably not half a second. 4.10s are fine for the street as long as you don't spend a huge amount of time on the highway, but honestly a lot of 4cyl imports have terrible final drive ratios, too. They don't have a gear as tall as we do in 5th, either. My '95 BMW 318i is running at 3000 RPM at just 70 mph. You won't be running that high, even after the gear swap to 4.10s.
Back to the drag racing part, if you're looking for improvement, sticky tires should come first. The 4.10s will only help you in the first part of the track. If you just blow off the tires on the launch, then those gears aren't doing anything for you.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Oct 3, 2012
  • Oct 3, 2012
keep the 3.55's. best gear ratio in my book!
twistedwankel
200
Spring Hill, FL
Oct 3, 2012
  • Oct 3, 2012
http://www.wallaceracing.com/Calculators.htm
You can use these calculators to give yourself a pretty good idea of what will happen just by changing one parameter in the formula.
ratio411
3,870
73
109
Pensacola FL
Oct 3, 2012
  • Oct 3, 2012
If you have an O/D transmission, and do not drive much on the open highway (interstate), then 4.10 gears will actually help your fuel mileage. Just a heads up. The engine doesn't work as hard in traffic when it has more leverage on the car, which saves fuel.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Jun 14, 2026
Mindseye007
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
