  • SN95 4.6L Mustang Tech
4.6 block
  • Thread starter Thread starter pnyxprs96
  • Start date Start date Nov 9, 2008
P
pnyxprs96
10
  • Nov 9, 2008
i was wondering how much can the 4.6 2v from 96 to 04 handle hp wise . just the block by its self and how much can a stock full motor handle like the rods and mains ect im sure its been asked sorry
mogs01gt
3,113
30
119
Ohio
Nov 10, 2008
  • Nov 10, 2008
The block can handle 1000hp+
S351Saleen77
423
Washington
Nov 10, 2008
  • Nov 10, 2008
I was wondering this same thing also. I have heard stock rods are the weak point.
Looking at a friends 99 S281 that has a Saleen supercharger. I have read where the stock rods are good for about 400rwhp and to stay in the 370rwhp range to be safe. Is this true??
Thanks, Tom
mogs01gt
3,113
30
119
Ohio
Nov 10, 2008
  • Nov 10, 2008
with a good tune, the rods are good up to around 425. The tune is the most important part.
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Nov 10, 2008
  • Nov 10, 2008
+1 the tune needs to be spot on. The blocks can handle a chit load of power, but the internals are another story. They say the rule of thumb is 420-430 with a really good tune.
trinity_gt
3,125
81
99
Canada
Nov 10, 2008
  • Nov 10, 2008
The iron block is a pretty stout piece. Even the cast crank is pretty tough if you keep the revs reasonable. The rods and pistons though... The rods have a very thin cross section and the hypereutectic cast pistons are as brittle as kindling. Detonate once under boost and you're more likely than not to break a ring land.
the98stang
2,408
Clovis, CA
Nov 11, 2008
  • Nov 11, 2008
Block itself can handle around 1000whp. The rods/pistons/bearings can handle around 400-450whp depending on the tune and blower type. Roots blowers are harder on the engine versus centrifugal. Less timing and more boost is safer. Advanced timing/low boost/high AFR is asking for trouble. Usually you want to tune these 4.6 for 11.0 AFR or less (with boost) to prevent detonation and engine failure.
S351Saleen77
423
Washington
Nov 11, 2008
  • Nov 11, 2008
Thank's for the tip on the AFR!
blubullett
535
Modesto, CA
Nov 11, 2008
  • Nov 11, 2008
Lots of people have made 450-475 fine also, im at 419hp with 11.6 afr for the last 25k and havent had any problems. And Im not easy on it. There is a thread from a couple weeks ago about how much a stock bottom end can handle. You should search it. It is pretty educational.
the98stang
2,408
Clovis, CA
Nov 12, 2008
#10
  • Nov 12, 2008
  • #10
There are some "freak" blocks out there. Cody (hotmustang) had a TT stang with over 500whp on the stock block for a while (until it was wrecked). I really think with the right timing/AFR/tune these engines can handle 500 +whp.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
9
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
