D
Deleted member 87397
Hey all I'm a 5.0 guy so I don't troll here too often but I'm having issues with an old 95 Crown Vic that has the 4.6 SOHC. I thought you all over here could give me some ideas.
Here are the facts:
Car was running great yesterday when it was turned off. Now it won't start.
Car has over 200k and burns a bit of oil.
Battery is strong and starter is cranking perfectly
Car has had a bad DPFE sensor for 2 years. Replaced it last night just in case that was an issue. (it's my bro's car and he was too lazy to change it.)
Fuel pump primes when key is turned and sounds pretty strong
Fuel will spray out the schrader valve when cranking.
All 8 plugs are brand new
Wires are in great shape and all 8 wires are getting excellent spark
Air filter is clean and throttle body is not gunked up at all
Car will start for a few seconds with starting fluid but runs like hell as if timing were off or a cylinder was down.
All sensors are plugged in
Engine has no major mechanical issues that I know of.
My only other thoughts are maybe a bad crank or cam position sensor or maybe the ecu. Is it possbile that the EGR could be gunked up bad and causing issues?
Any ideas would be greatly appreciated, as I need to get this car up and running soon. Thanks
Here are the facts:
