Here is my dilemma. I just recently purchased a '96 GT with around 140K on it. The car is in good shape and seems well taken care of. I have had it for about 4 months and just recently added an off-road H-Pipe and flowmaster cat back system. the other day, I was backing into my garage and when i gave the car a little gas, some blue smoke came out of the exhaust.
I have been observing the smoke for the last two weeks. It ONLY occurs under the following conditions:
1. Letting the vehicle idle for longer than 5 seconds, and briefly touching the throttle. it smokes blue for about 6 seconds then quits.
2. Doesn't smoke while cruising, full-throttle or cold startup.
3. Doesn't smoke untill the engine has warmed up a little, will not do it when the engine is cold and you let it idle then bump it.
4. Has consumed oil since day 1. Uses about 1.5 QTS between 3000 mile oil changes. I use a 5W30 weight oil.
5. Did not smoke untill the H-Pipe install, drove for several months before I added this, no smoke at all, although still used oil.
My only explanation is that the converters were cleaning up the exhaust enough that the smoke did not make it out the tailpipe. I DO NOT have my O2 sims in place yet, but the fuel mileage is really close to when it had cats, and the check engine light isn't on yet, although i know it will come on sooner or later.
I was in line for about 7 minutes in a drive-thru the other day, and noticed that it was smoking continuously toward the end of the wait, and smoked decently bad upon takeoff from the drive-thru, but quit once i got going down the road a short ways.
I'm thinking valve-stem seals. I have alreay replaced the PCV valve and checked the PCV system operation, all appears normal.
Anyone else have some ideas??
Thanks!
Thanks!
No thanks, i do enough mechanical work at my day job.
