4.6L in a 73
The wiring is also in the special needs category. It can be done for sure. We have a local that has that engine in a Factory Five Cobra. Make sure it has the power you want for the cost involved. Everything is out there for the job.
I was thinking the 73's bay would be wide enough. Although I do not have the 4.6 to measure.
I am kicking myself, because I ran across an 01 with a blown motor for $1000 about 3 weeks ago. I passed on it because I have to many projects. Then this one comes along...
The block on almost all modulars is aluminum which help a bit with the weight. The only Mustangs (that I know of) that had iron blocks were the 03-04 Cobras. Other cars did have iron blocks but not Mustangs.
Don't do it. The 2v motor is crappy (compaired to a regular windsor) unless you put a set of heads on it and a good intake manifold which ain't cheap.
Go with a 351w and put some fuel injection on it.
600lbs was the listed weight.
I have a cleveland that is supposed to go back into it. I was toying with the idea of a modular, since its a deal. My wife would jump for joy if I parted with the vert. She hates driving it.
