4.6l out of a thunderbird in a stang?
American_Muscle
189
Hey guys,
I'm stationed overseas in Germany and now have a spun bearing in my 01 gt.
Getting an engine over here is hard.
But now I found a 4.6l out of a 92-93ish (sometime in that range) out of a Thunderbird.
Would it be a good idea to swap it over to my supercharged 01?
I would swap over the heads etc.
I think the tbird 4.6 has a higher compression.
How long would it last with 350 rwhp?
Does everything swap over?
Blower belt also?
Thanks
Patrick
Hey guys,
Blower belt also?
Thanks
Patrick
TBird's didn't get the 4.6L until 94. Personally I would pass on it if you have an 01, it would take a fair amount of work to put that in your car.
The only 4.6L engines that came in the Thunderbird worth any serious consideration are the '96-'97 engines. These were essentially the same as the '96-'98 Mustang GT. The '94-'96 engines weren't as well put together as the later ones (pirated from the early Crown Vics and Lincoln Town Car) and would require a lot of mix and matching of parts in order to afix your '01 PI hardware to them.
This thread is getting a little bit side tracked...
All you want from the TBird is the shortblock minus the oil pan. You will need your oil pan from your engine to fit into your K-member of your mustang. You will need to swap your heads, intake, fuel rails or whatever the 99+ cars have for a fuel setup, headers/exhaust manifolds, engine front cover, etc. Using the TBird shortblock and your PI heads will pump up the compression ratio a full point which will yield more power than what your stock motor and setup made( your car and the TBird stock were roughly 9:1 - 9.4:1 compression, TBird shortblock/PI heads will yield around 10:1 - 10.4:1 compression ). With the ****ty stock pistons/rods of the factory 4.6, I wouldn't want to put a SC on that high of a compression ratio. With what I have just said now, you should be seeing why I recommended what I did.
