  • SN95 4.6L Mustang Tech
4.6l rough idle
  • Thread starter Thread starter turbochargedv8
  • Start date Start date Mar 18, 2009
T
turbochargedv8
  • Mar 18, 2009
i have a 2001 ford crown victoria with the 4.6l 2v modular engine and it idles like it has a wild cam in it when i unplug the vacuum line to the egr valve diaphram it idles fine i replaced the dpfe sensor with no results any tips
squeak93
2,342
414
164
Joplin, Missouri
Mar 19, 2009
  • Mar 19, 2009
Check for vac leaks around the egr valve.
Rickyll7
718
  • Mar 19, 2009
If you repost your problem with some punctuation, it may be easier for us to understand what your issue is. It's difficult to understand exactly when you car idles rough. Is it before or after you disconnect the vacum line?
schoffs4
17
  • Mar 19, 2009
check your egr vacc solinoid [stuck open] you shouldn't get vaccume at idle from your egr valve vacc hose follow the vac line from you egr you will fine a vacc solinoid
T
turbochargedv8
  • Mar 20, 2009
i figured out what was wrong i had the wrong vac line going to the egr valve i had to swap it with the one i had going to the evap purge valve i just pulled and reinstalled this engine
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
