  • SN95 4.6L Mustang Tech
400HP 2V N/A....Going back to my roots....
  • Thread starter Thread starter Yel2002GTAuto
  • Start date Start date Sep 26, 2022
  • 6
  • 7
  • 8
First Prev 8 of 8
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Feb 2, 2024
#141
  • Feb 2, 2024
  • #141
So knowing what I know now compared to stages of cams..i.e. stage 1, 2 ,3 ect...I know exactly what is needed for my or any set up.... its all about usable cam profile based on heads used, flow, displacement, and intake... sometimes you read the descriptions and it tells you rpms, stall to use or other helpful tools...but those are just shelf grinds.... optimization is the key and you can broaden your power curve and power by selecting the correct tining events and build a custom cam pretty easily... don't get me wrong...off the shelves are good for mild bolt ons or upgrades but to truly tailer to your combo a custom grind is definitely needed..
J
jb232004
Ilinois
Feb 4, 2024
#142
  • Feb 4, 2024
  • #142
Yel2002GTAuto said:
First off, usage.... is your car a daily driver, street strip, or road racer.... depending on use, profiles for cams and intakes will determine the rpm ranges you will need max power and TQ at... For most of the crowd it is street strip and/or daily drive or both so I will focus here since this is in line with what my goals are...
So, unless you are building a full out drag car cams are the biggest bang for adding power and need to be balanced for drivability.... Intakes are limited for the 2v and the best intake in my opinion by far is the PI intake...once you go to a larger intake like the TFS or Victor Jr... you drastically shift the power curve up and
Most people do a stage 1 to stage 3 cam for their 2v mustangs as an example as they don't want to go too big thinking drivability down low will suffer... This can be correct if you go to big a cam with an LSA over 110 and up... When you go with a bigger duration cam this will shift the TQ and HP curve up in the graph and starts impacting low end TQ/HP for drivability.... but how can you get the best of both worlds?
Lower the LSA down .... some theories are that lowering the LSA down effect low end drivability or idle quality... it does to some extent but having a cam match flow for head/intake and lowing the LSA can net great low end Power/TQ without sacrificing top end power... get the best of both worlds and a nice aggressive idle with the choppy cam sound... as long as the cam events are inline with the build, there really isn't any downfalls unless your cam doesn't match our set up..
J
jb232004
Ilinois
Feb 4, 2024
#143
  • Feb 4, 2024
  • #143
Good stuff.
Reactions: Yel2002GTAuto
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Feb 4, 2024
#144
  • Feb 4, 2024
  • #144
So now that we better understand cam characteristics, let's talk about how to select a cam based on engine specs you are building...
Max piston speed for a solid street strip build with good forged internals is 4500 ft per minute... very reliable is 4000 ft per minute.... so here is the basic math...
Stroke x desired rpm / 6...
So for a stock 281 the stroke is
3.543 so x say 7000rpms = 24,801...then divide by 6 = 4133.5 ft per min...
So for my 5.3l build the stroke is 3.75 x 7000 /6 = 4375 ft per minute which is in a safe threshold...
Now knowing where the PI intake likes peak power is around 6100 tops you add about 500 to 600 rpm for shift points so around 6600 to 6700 rpms... which would be around 4100 feet per minute...
So knowing what cams to go with for peak is around 240 244 range for optimal balance with engine speed and PI intake as example..
Ed
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Feb 4, 2024
#145
  • Feb 4, 2024
  • #145
Question:
Is this going to amount to anything? What's the goal here? Are you about to start building an engine?
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Feb 4, 2024
#146
  • Feb 4, 2024
  • #146
So in theory... the cam for the stoker to optimize power and tq should come in around 108 LSA, 240 to 244 duration with a lift of .600... since the ported TFS heads flowed peak to .600 lift that would maximize the power from 4000 rpms for peak tq and maximize peak power to 5900 to 6100 rpms....... makes sense one you use the formulas, see real world testing and results, and know the flow numbers for the heads...
Ed
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Feb 4, 2024
#147
  • Feb 4, 2024
  • #147
Goal is to be building soon....I have some of the valvetrian components already, just deciding on some of the final parts to use and will have L&M Engines build the shortblock... resleave the WAP block to 94mm and use some of my existing parts for the build...I was going to start the build about a year ago with a 5.0 boss block but Ford Racing had on back order for pat 2 plus years now..plus tons of other 2v parts are hard to find or backorded as well...goal is to be building soon as soon as I get the crank and rods...which are backorderd as well..
My switch to a different brand but was just researching and sharing my findings at this point...plus this gave me time to pull apart the car and detail it from top to bottom...hopefully I get her up and finished soon...
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Feb 4, 2024
#148
  • Feb 4, 2024
  • #148
Originally, brenspeed offered a 5.3 boss build shortblock for 6300....when I went to purchase things got backorded about 2 years ago...so had to weigh out all the options..
Ed
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Feb 11, 2024
#149
  • Feb 11, 2024
  • #149
So I selected my profile for what cams I want to use...108lsa, 240/246 duration .050 and .610 lifts using dual pact valve springs and GT 500 rockers as these weigh 5grams less than normal rockers and have 25% better oiling.... hopefully I can get all the parts in then next several weeks..
Reactions: jb232004
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Feb 13, 2024
#150
  • Feb 13, 2024
  • #150
So I contacted Jim Cushman on the cam profile and he is looking into it for me...hopefully this will work with what I am trying to do..
Ed
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Feb 15, 2024
#151
  • Feb 15, 2024
  • #151
So there is a great video by Unity Mostorsports Garage on YouTube search - Camshaft Lobe Separation Angle: The Untold Truth of LSA!! How to Pick LSA the right way@DavidVizard
This was another testing video for LSA only with same cam specs and shows how it performed on a 2 valve...
Basically picked up 12-15hp going from a 114plus LSA down to a 112 LSA... then picked up another 10-14hp going from a 112 to 108lsa...
Basically gained 20 to 30 more HP just from the LSA change...
I belive most cam companies design there cams towards smoother idles with the intent of a stage 2 or 1 cam NA that is still inline with adding a supercharger, turbo chargers or other type of power adders.... Looks like cam companies never really tested their products to get max NA power .... most of their cams are geared for normal bolt ons.... now most of the cams will fit under stock heads... for those that have ported heads, TFS Heads or rebuilt engines, you are really leaving a lot on the table with an off the shelf cam..
For a 108lsa, you will likely need notched pistons but you can notch with the heads off or have the pistons notched when you do a rebuild...
Take a look at this video and you will be pleasantly shocked at the results... just didn't pick up power in the top end... picked up 20-30 hp and tq throughout the graph... same type of testing like Richard Holdener did on the other video i described... plus David Vizard discusses as well... great stuff..
Ed
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Apr 3, 2024
#152
  • Apr 3, 2024
  • #152
Hi everyone...been a min so wanted to give an update..I was laid off from my job so project is on hold atm for past several weeks...going through interviews so hopefully be picking up soon...still got that itch so I will keep you all posted..
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Apr 3, 2024
#153
  • Apr 3, 2024
  • #153
Also, looking at ms3 pro now as this is a fully controllable after market computer..you can basically tune your car on the fly, change any or all setting, and run flex fuels and hook up wide bands directly..love this technology...supposed to be way faster processor so better drivability as well..cool stuff..
Y
Yel2002GTAuto
233
26
38
Granit City, IL
May 31, 2024
#154
  • May 31, 2024
  • #154
Hi all...still in pause mode as I am still looking for work...did a little work on interior...I will post some pics soon..
ED
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Dec 5, 2024
#155
  • Dec 5, 2024
  • #155
Hi all....been a minute since I have posted. So...I finally found a great job and can re-engage on my process to rebuild my engine soon. Economy sucks and good jobs are scarce. Interviewed for over a dozen positions over the past 9 months and finally found the right fit... looking to posting and interacting with everyone....
Ed
Reactions: LILCBRA
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Mar 11, 2025
#156
  • Mar 11, 2025
  • #156
Hi all, been busy with my new Job so not much time to play lately... carving out some time to work on the car soon so getting that itch again.. been trying to save some funds for the upgrades but having to save a bit longer.... looking forward to playing with the Stang again soon..
Ed
89ripper
925
309
103
Rockford, Illinois
Mar 11, 2025
#157
  • Mar 11, 2025
  • #157
The weather is startin to get nicer....
Bullitt347
I have been doing it wrong this whole time
4,047
3,101
204
Middle of Maine
Mar 11, 2025
#158
  • Mar 11, 2025
  • #158
Normal bolt on engines don't make max N/A HP.
That is the nature of a stock/mostly stock build.
Max N/A HP requires Max HP parts, not just the camshaft.
Y
Yel2002GTAuto
233
26
38
Granit City, IL
Mar 11, 2025
#159
  • Mar 11, 2025
  • #159
Totally agree with you brother... just was pointing out that even with Max HP parts and builds, there were no off the shelf camshafts that utilized specs for these types of builds... nobody really tested or put up numbers when done... I have known several engine builders and tuners that helps those order aggressive cams to suit their builds but most with custom engines only used off the shelve cams... stage 3 to 5... the lifts and LSAs on those were really robbing them of power based on their engine mods...... Plus only a few tested Compression Ratios over 11 or 12 to 1 so not many knew how high they could go... pump gas safely with 2v Aluminum block... 12 to 1 with right custom cam profile... 11 to 11.6 to 1 safe all day with proper tuning..... most stayed around 10.5 to 1 or lower....
Bullitt347
4,047
3,101
204
Middle of Maine
Mar 11, 2025
#160
  • Mar 11, 2025
  • #160
Given the number of combinations available to build an engine, it is no wonder that most OTS camshaft don't achieve max potential.
You would have to have a catalog of hundreds of thousands camshafts to meet every variant. Which is why when "most" people build a max effort build, or a serious street engine build, they pay the extra $ to get a custom cam.
Which is what I did on my build. There were simply no cams on the shelf that came close.
  • 6
  • 7
  • 8
First Prev 8 of 8
Looking forward to collaborating with my new community
  • phil2001svt
  • Sep 24, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 10, 2026
phil2001svt
C
New mustang owner
  • CPH89LX
  • Apr 26, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 27, 2026
91AOD5.0LX
R
New name but not new here
  • Ruckus50Gt
  • Mar 20, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 20, 2025
91AOD5.0LX
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
