400hp 5.0
  • Thread starter Thread starter ScottMH
  • Start date Start date Mar 2, 2010
1 of 2 Next Last
ScottMH
18
  • Mar 2, 2010
hey guys i have a 92 mustang gt with the 5.0. i want to stroke it out, put alum heads and a cam. what parts/combo should i be looking at to get me in the 400hp range
clement
1,104
52
59
Oak Cliff
Mar 2, 2010
  • Mar 2, 2010
400 flywheel or rwhp? et goals? car weight? stick or auto? budget? daily driver/street-strip/or race car?
ScottMH
18
  • Mar 3, 2010
400 at the rear wheel, its a street car wont see any strip time, T-5 manual, no budget, casual use car.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Mar 3, 2010
  • Mar 3, 2010
Easy answer? Boost and aluminum heads.
Hard way? High rev, high compression 347.
R
RatStang
544
  • Mar 3, 2010
... and option #3. Hellion Turbo kit. Leave everything else stock.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 3, 2010
  • Mar 3, 2010
I went the 347 all motor route. Not quite at the 400hp mark yet, got about 35hp to go but i'm about to do an intake and carb swap...might get a tad closer i hope. Remember that 400 at the wheels is around 460 at the crank if you have a 5 speed so you really need to build it right.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 3, 2010
  • Mar 3, 2010
400hp is easy with a 347. Doesn't take high compression and can be done under the factory rev limiter.
I would use trrickflow fast as cast or afr 185/afr 185 comp heads with a holley, rpm II, tfs R or a victor manifold, custom cam from Ed Curtis @ Flowtech induction, 42lb injectors, 75-90mm tb, 80-90mm mass air, 1 3/4" longtubes. I just designed you an easy 425+ hp
stykthyn
5,232
2,652
223
gainesville
Mar 3, 2010
  • Mar 3, 2010
Its funny how many people say they want a 400hp street motor and then when its all said and done they are happy with an explorer/cobra top end swap.
I'm with dontgivaratz. Go turbo and leave the rest stock.
clement
1,104
52
59
Oak Cliff
Mar 3, 2010
  • Mar 3, 2010
for that amount of power, a 347 + a victor jr + a carb + the right HR + a set of TFS FAC 190s will do it all day long at under 11.0:1 compression at around 6000rpm. and if the cam is right itll drive great too.
and the dynamic cylinder pressure of a typical NA 347 is far less than that of a boosted stock motor (with the stock cam) which will make running on ****ty pump gas much easier with the 347.
ive dicked around with centrifical superchargers for the last 15 years and turbos for the last 12. the biggest thing about getting them to run and stay together is engine management. if you cant spend a lot of time on a laptop tuning to get it right you will be fighting a loosing battle, or it wont make the power and wont run as good as it should.
Dino Dino Bambino
1,673
90
79
Cyprus
Mar 3, 2010
#10
  • Mar 3, 2010
  • #10
Since you're looking for 400rwhp (460 crank), you'll need either forced induction on a 302 or a N/A 347. The latter will need to make peak HP at ~6000rpm and spin safely to 6500rpm so you'll need a combo that'll get you there:
347 stroker, 10.5:1 CR
TFS 190cc FAC heads
CompCams XE276HR-12 cam
TFS R-series intake
30lb injectors
1.7 roller rockers
75mm TB with 76-80mm MAF
1-3/4" long tube headers
Dyno tune
ScottMH
18
#11
  • Mar 3, 2010
  • #11
im looking to stay N/A. what about 400 to the crank?
7upstang91
936
124
74
Florida
Mar 3, 2010
#12
  • Mar 3, 2010
  • #12
This will work!
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 3, 2010
#13
  • Mar 3, 2010
  • #13
Why build a stroker just to make numbers a stock 100k mile 302 shortblock can make? Listen to people that have the parts and have done it.
clement
1,104
52
59
Oak Cliff
Mar 3, 2010
#14
  • Mar 3, 2010
  • #14
holley systemax, TFS heads, an anderson n4 cam and all the accessories on your stock shortblock.
ScottMH
18
#15
  • Mar 3, 2010
  • #15
why would you go with the holley systemax kit then change the heads and the cam.
clement
1,104
52
59
Oak Cliff
Mar 3, 2010
#16
  • Mar 3, 2010
  • #16
i wouldnt use the kit, just the intake. sorry i didnt specify. that is an 11 second combination on motor, stock shortblock with tuning, gear and a good driver.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Mar 3, 2010
#17
  • Mar 3, 2010
  • #17
what he said!
SpartaPerformance
2,517
61
89
Long Island NY
Mar 3, 2010
#18
  • Mar 3, 2010
  • #18
Scott as you can see by the posts above , there is no clear answer. That is the beauty of the Mustang, so many way to get what you want. it really depends on what you want, muscle or forced induction, small or large cubes, carb or efi, what your budget is, mechanical skill etc.....
stykthyn
5,232
2,652
223
gainesville
Mar 4, 2010
#19
  • Mar 4, 2010
  • #19
mostly on budget, everything else follows after. To be done right a 400hp combo will run 4-5k.Then you have to do all the supporting mods to the driveline and suspension.
ScottMH
18
#20
  • Mar 4, 2010
  • #20
guess i should come clean, the engine is for a customer of mine. ive built many SB and BB Chevys, fords, and mopars including a 472 Hemi. but they were all old school carbed engines. ive never done a efi engine before. my customer wants to build a stroker and wants around 400hp thats all he told me. the guy has a lot of money but if i can keep the total motor build (including machine work) at or around $5-6k i think he will be happy. so, i know he wants a stroker, heads, and a cam for sure. looks like a intake change is in order too. i am also going to have a t-5 built to spec ones the motor is dyno'd as far as the rear end he never said anyting about it. i dont know if its already done or what
1 of 2 Next Last
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
