I have 1994 5.0 motor, putting on AFR Renegade 165 heads, don't know if I should put new pistons in because the hydraulic roller cam is probably going to have .540 lift and roughly 227 and 240 duration at .050( it's going to be a custom grind. Should I just go with the stop pistons in motor with 4 valve reliefs or get new pistons (worried about piston to valve clearance) if you recommend new pistons, what should I get then , can you give me brand and part number would help
