So some might remember I began installing a 460/5-speed in my 85 awhile back. Well, now its done except it wont start. To give you some info, its a 466 with 9/1 comp backed by a TKO600 5-speed. The hard part was finding a starter so I tried my original 5.0 starter and it bolted it. When I tried starting it, the starter was very slow like if the battery was low. I tried 3 batteries and even a jump but the same problem. Then I thought maybe the 5.0 starter was too weak so I tried a 460 starter from a torino 460/4-speed but it wouldnt even bolt in. Then I tried a starter from a 460/5-speed truck and it bolted in but with the same affect. I thought maybe since the battery is mounted behind the pass. seat the cable was too long so I threw on some jumper cables to go from the solenoid to the battery but the same thing. Then I thought maybe the battery ground was bad, so again I aided with the jumpers to add 2 more ground sources but the same affect. Could a bad solenoid cause this. 3 batteries, extra grounding wires, 2 starters and nothing. I thought the engine was too tight but it turns like any other engine with a breaker bar. I cant figure it out. I thought if the solenoid was bad it would either stay closed or stay open, not make the signal weak to the starter. Can you guys think of anything. Everything is done except this. I'd post some pictures but everytime I ask people how to do it on here, nobody answers or they laugh so thanks for the help on that one.
