I havent met anyone on here with a 460 and Tremec so lets hope for the best cause Im kinda on my own with this one. In case you are wondering the crank was already set up for pilot bearing, Bellhousing is lakewood, only that will work, 176 tooth ford powermaster starter, TKO600 trans, prothane tremec tranny mount, stock crossmember pushed all the way back, unmodified Ford racing aluminum driveshaft which barely fits cause the 460 moves the tranny back, regular 302 adjustable clutch cable and regular speedo cable and gear. Also, shifter is in stock location so dont worry about that. Let me know if you want to know anything else since this is a pretty rare or new combo on these boards. I think its a worthy one because the TKO has overdrive which should regain gas mileage everybody *****es about when they talk 460s. Also, the trannys are rated to 600 ft/lbs so its plenty strong for a street 460. The motor is ass tight to the firewall, but there is plenty of room up front, but mount the fan in front of the radiator unless its really skinny. I was able to reuse 85 carbed fuel lines without modding, with 82 hood scoop it should fit under the stock hood. I must say the Lakewood bellhousing is a horrible design though!!! First, they dont clearance around the mounting bolts, so forget about using sockets, only wrenches, so install the bell and starter before installing the motor. Secondly, the mounting hole for the clutch cable to slide through was too small and I had to drill it out. Third, there is no way to fit exhaust around the wide lip of the housing without grinding so forget about it being SFI anymore, lol. This was suppose to be specifically designed for this conversion into a Fox but it blows. Probably no research went into this at all. Im also using stock manifolds so I cant even dare to say if this would have worked with headers. Best to install everything as one whole unit with tranny and use a tilter with your picker. You dont need to have the car on jacks but make sure you have plenty of ceiling cause the hoist gets pretty high.
