I was wondering if I could use the 4cyl brake lines with the 5.0 mastercylinder and booster. Is it possible? Is it gonna affect the braking perforamce? I plan on running the 5.0 discs and the 8.8 rear end. I see that the rearend line is different on the two, but I am understanding that if you run dumps you dont have to worry about the line, which I plan on doing. If I were to switch to 5lug 4 discs would I still be okay with the 4cyl lines? So will the 4cyl brake lines hook up to the 5.0 parts; is my main concern. Thanks guys.
