Fox Cobra Style Brake booster kit
Crigano
111
12
28
Westchester NY
Hi all. So I just changed over to disc brakes in my 93 5.0 hatch.
I had a new cobra style brake booster and master cylinder installed.
Part: disc brake kit
Part: brake booster master cylinder
The lines were bled , and theres no air but the pedal has more travel and feels softer than the original brake booster that was in the car.
Has anyone changed over to this style and had the same results?
It’s a bit spongy but I’ve never known these cars to have any other feeling lol.
That kit uses SN95 rear calipers (38mm piston)
The 93 cobra uses the stock 60mm calipers and 45mm rear calipers. With a smaller rear piston (that what the 93 Cobra would have had stock) your pedal feel should actually be a bit on the firm side as you probably should have used a 94-95 cobra 15/16” bore MC. In fact once you have this setup dialed in if you find braking response not where you’d like I’d recommend changing to the 15/16” MC
But Since your pedal is soft, it likely means you still have air in the system, and usually when a new MC is installed it likely is in the MC.
With engine off, if you pump the brake pedal, does it ever really firm up? No sponginess? Or is there still travel and give?
If so, I’d bench bleed the master cylinder again followed by a full bleed.
It requires a machine that lightly pressurizes the master cylinder. It forces fluid from the top down. I've had very good luck getting stubborn trapt air out. Alot of service centers sell a machine brake flush for a decent price.
Thanks for the explanation. No, I don’t think that was done. From what I’ve researched over the past few days, it looks like this is normal pedal feel with a bigger booster.
If I want a firmer pedal, I should replace the front brakes with a 4 piston caliper from bremo, (since they’re the only ones that maker bigger brakes for a 4 lug)
