- Jan 10, 2011
- 400
- 113
- 63
I'm doing a 4-8 swap on my '93 LX. I have the shortblock almost ready all but the camshaft (which will be one of the last things to get). Mahle flat tops and stock length rods/3" stroke (306"). Heads will be AFR165's unless I should go with 185's? I have an RPM II intake and will be getting a 70mm TB/EGR spacer. I'd like to somewhat duplicate this:
Edelbrock Performer RPM II EFI Intake Install and Test - Muscle Mustangs and Fast Fords Magazine
That is impressive for a little 302" engine. If I could get 350-370 HP I'd be tickled BUT it needs to be streetable-as I drive quite a bit for work, etc.
My questions. The article mentions 24lb injectors, but doesn't say what computer to use? I currently do not have injectors nor a computer. I also have a stock MAF-which is probably going to have to be changed as well (I planned for it). What about the 24's? Do you think they will be enough? Or should I go 30's? Driveability takes precedence over maximum HP-but I don't want a slouch. For the cam, I'll more than likely go custom cam-FTI or I know another guy who can grind whatever I want. I like Ed's stuff though. Rest of the car is just a typical Fox body-T5 (2.95), haven't decided on a clutch yet, 8.8 w/3.73's, etc. I also have a Fidanza aluminum flywheel that'll be going on it-I already have it so that's what I'm using. I can change to a steel FW later if I don't like the Aluminum one.
The main goals here are 1: driveability, 2: crisp response, and 3: decent HP. I don't need to get carried away with a 500 HP monster-I have race cars for that. My goals are to have a car that drives like my old '84 GT. Little choppy at idle, but lays down some decent power. Any suggestions you guys can give will be helpful-I'm a bit of a greenhorn when it comes to 5.0 EFI stuff. 2.3 turbos I can mess with some but I've never done a 5.0, and I know carbs fairly well and mechanical constant flow injection.
