5.0 Engine
  • Thread starter Thread starter DRock9
  • Start date Start date Aug 26, 2006
D
DRock9
359
  • Aug 26, 2006
My Dad proposed a great idea, instead of always pulling my motor to install parts i can buy another one separate from the car and build that up and then just swap it when im done. I plan on getting the Trickflow Top-end kit and headers but that is pretty much the extent of my engine mods, maybe 24lb injectors. My question is, what would be the better option.
If i got another engine i could probably do the work myself, where as if i didnt i would have to pay the mechanic to do the work for me because i cant pull a motor. I would imagine that it would result in less downtime for my car and also be less money-wise but im not exactly sure. Also it would give me a good time to upgrade the engine to something better but id like to keep it as cheap as possible for whatever engine i end up getting.
Has anyone had experience with this or can tell me whether this is a good idea or not. And also how much would a 5.0 engine go for? Thanks for the help!
R
R2D2
Aug 26, 2006
  • Aug 26, 2006
I see no need to yank the motor for heads, intake, cam and exhaust install
RYC CUKR
1,437
Orlando
Aug 26, 2006
  • Aug 26, 2006
No need to pull the motor for HCI but if you want to do it at your leisure then getting a spare motor and doing the work on the stand is a good idea.
I have a spare non HO motor that I plan on using for a 331 build up. Its nice not to have to rush to have it back together in time for work on monday.
D
DRock9
359
  • Aug 26, 2006
I read it was cheaper and faster to pull the motor. It said it would take 3-4 hours if you pulled it vs. "a weekend" if you left it in.
If i take it to a mechanic how long on average would it take them?
revedup
63
S.F. Cal,
May 21, 2007
  • May 21, 2007
whats a shop charge to remove and install an engine anyone know/
Alsoto rering and change bearings woul;dnt the motor have oto be out of the car??
D
DRock9
359
  • May 21, 2007
Yes i am pretty sure the motor would have to be pulled, but I am not sure how much they charge to remove and install an engine...I know in these cars if you are good you can easily have it done in under a day.
revedup
63
S.F. Cal,
May 21, 2007
  • May 21, 2007
Does any one have an idea charge labor wise a shop may charge for a simple engine remove and replace!!! In the S.F. bay Area? thanx anyone???????
ShortThrow50
923
Pa
May 21, 2007
  • May 21, 2007
why not? its the easiest motor i ever pulled as long as you pull the tranny with it. It makes for a cleaner install and you can clean up the whole engine bay and engine. paint the short block ,etc, etc. Do it once and do it right. Ill be dropping this back in in about a week or so
from this
to this
Sicarius428
2,085
May 21, 2007
  • May 21, 2007
If you are going to buy build a motor off a stand, you might as well get the shortblock rebuilt or freshened up. Who knows about these tired HO blocks on craigslist... If you do the top end kit in the car, it should take about 10 hours if you know your way around the engine compartment. Honestly I had more problems getting the exhaust to line up than anything else.
Kevin
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
May 21, 2007
#10
  • May 21, 2007
  • #10
drive what you have in the car now, get the spare engine on the stand, since its on a stand and going to have some decent heads and stuff on it, go ahead and tear her down and refreshen it, could be simple and could just hone and rering the engine, if its real old and tired bore it over a small bit.
take your time. dont get in a hurry with it, thats asking for trouble
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 21, 2007
#11
  • May 21, 2007
  • #11
^^ I agree
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
