5.0 Flywheels
  • Thread starter Thread starter slave4thestang
  • Start date Start date Apr 17, 2007
slave4thestang
  • Apr 17, 2007
ok im looking for a steel flywheel thats been lightened to some degree from stock. i cant seem to find one if anyone could point me in a good direction it would be appreciated.
AnthonyR23
661
Ontario
Apr 18, 2007
  • Apr 18, 2007
have you looked through mustangs unlimited's site?
Sevan
558
IL
Apr 18, 2007
  • Apr 18, 2007
u cant use a lighter flywheel with a stock engine. stock engine is balanced to 50oz flywheel.
T
tripleblackragtop
12
Royal Oak, MI
Apr 18, 2007
  • Apr 18, 2007
I've seen listings for a lightweight steel flywheel from this place under XACT Streetlite and Prolite product lines, but I have no first hand experience with one.
http://www.advancedclutch.com/
You can use a lightweight flywheel with a stock engine. You just have to make sure it has the 50oz-in imbalance, and not the 28oz-in imbalance or 0oz-in neutral balance. The imbalance on the flywheel (and the crankshaft damper) is meant to correct for the imbalance of the crankshaft so the assembly is balanced.
G
getusummm
156
  • Apr 18, 2007
Sevan, does that mean I should send my aluminum flywheel back? It is much lighter than stock, but balanced for 50oz. Maybe you can shed some light on this subject before I wreck my engine.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 19, 2007
  • Apr 19, 2007
It if is balanced with an imbalance of 50 oz you can use it with no problems towards the engine.
Sevan
558
IL
Apr 19, 2007
  • Apr 19, 2007
getusummm, 5spd GT is correct. I recently pulled my motor out and went with a 347which is balanced to 28oz. I had to buy a 28oz flywheel and dampner. I have no experience with the imbalance flywheels.
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
