I have a 98 V6 5 speed and was thinking about putting a 5.0 in it. Has any one ever done this? Would I be able to use the tranny thats in the car now? Any info on this would be a big help. Thanks
if you get the swap done and working it should be real sweet
But in all reality it will be a lot of work to do properly. Basically every part of the V6 from fueling to cooling and electrics to plumbing will really need changing. G/box and rear may hold for a while but I guess if you want a V8 you want POWER - this will more than likley break most of the V6 only parts with a bit of abuse.
can be done but the entire drivetrain and rear would need to be swapped. the t-5 in a v6 is too weak even for a stock 302 as is the rear. if it were ever seriously considered a wrecked donor car would be the best thing.
