5.0 No Crankey Or Starty
Snow5.0
22
Ok guys this morning I got into my stang to goto work and it turned over, started and died. Now thats not the strange part, I have a cam and some other stuff so it always has hard time until its warmed up.
The strange part is I went to start it back up like i always do, and NOTHING. NO cranking, NO clicking.....nothing. Now I could hear the fuel pump kick on for a few seconds, I had headlights, radio and ll the stuff.
So I did some searching on here and read some things that JRICHKER has stated to do, but from what I can tell all his stuff is for if the car cranks over.
So in short after my searching and reading I think, it might be the starter solenoid switch, so I thought I would post and see what you guys think. If you dont think thats the problem then I will start going through the cranking not starting stickie. Thanks Chad
Jump the solenoid.
I believe toward the top of the solenoid there will be a little connector that sort of "pops on" to the solenoid. IIRC it's a red wire with a blue tracer. Take the connector off and connect the positive post on the solenoid to the little post that the connector was on. That should cause the starter to engage.
Keep reading... I have checklists for most of the common problems...
No Crank checklist for 5.0 Mustangs
Revised 05-Oct-2010 to update Fluke references.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
Thanks for all the info JRICHKER, I know you didnt have to reply with all of that. So again thank you and Ill let you guys know the problem when I find it. I have read a lot of your posts and they have helped me a great deal.
If it is battery corrosion or if you need a new battery and want to keep it like new, please use battery terminal anti corrosion spray. Unlike most problems, this one can be fixed with what come in a bottle.:rolleyes:
Permatex and 3M are the brands that come to mind, but it sprays a red film that prevents battery cauliflower. It also comes in gel. Avoid the felt washers and grease. The spray and gel versions get it done better than grease and still allows good conductivity. My batteries often last at least 8 years and my terminals are always ready. Clean, dry and coat all the parts inside and out (and spray the posts) prior to assembly. Top coat after assembly and your terminals and posts should always be ready. I use a paper towel to mask what I do not want made pink.
cool thanks for the advise 7991LX, I am still working on getting it figured out. I am taking my batt. to be load tested after work today Ill keep you guys posted. Oh BTW I have tested the starter and the starter solenoid and they check out fine. So its either the batt. or the ingnition switch.
One question for Jrichker..or anyone else LOL, is it possiable for the car to start with out a netural safety switch on the trans? And also is there a safety switch on the clutch as well ? I know a few other vehicles I've had have had thoes and given me issues.
I have nothing electronic connected on my trans and my car starts fine, BUT, I have a jump button on the solenoid. You need the NSS hooked up AND there is something with the clutch pedal itself. I had a buddy who had a '93 notch with a 363 and a C4, original T5 car, he still had to press the still-existent clutch pedal to start his automatic car lol
What the NSS (Neutral Safety Switch) does:
5 speed transmission: It has no connection with the starter, and the engine can be cranked without it being connected.
Auto transmission: It is the safety interlock that prevents the starter from cranking the engine with the transmission in gear.
What it does for both 5 speed and auto transmission cars:
The computer wants to make sure the A/C is off due to the added load on the engine for the engine running computer diagnostic tests. It also checks to see that the transmission is in Neutral (5 speed and auto transmission) and the clutch depressed (T5, T56, Tremec 3550 & TKO)). This prevents the diagnostics from being run when the car is driven. Key On Engine Running test mode takes the throttle control away from the driver for several tests. This could prove hazardous if the computer was jumpered into test mode and then driven.
There is a clutch interlock on the clutch pedal on 5 speed cars that prevents the engine from being cranked unless the clutch is depressed. See the diagram of the typical start circuit that I posted.
