5.0 pouring coolant
  • Thread starter Thread starter Shaolin Crane
  • Start date Start date Oct 9, 2008
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 9, 2008
  • Oct 9, 2008
started my car up to move parking spots and as soon as i did i noticed lots and lots of fluid pouring out the bottom of my car, as soon as i realized it i tried to start it again and it struggled alot but finally started, as soon as it started i let it run for a few seconds and shut it off and looked under the car and noticed coolant leaking out from behind the passengers side motor mount and i immediatly thought it was a freeze plug leaking since the water that came out was RED so since now i realized the car was not taken care of by the previous owner im starting to think more and more that its is a freeze plug because of the rust, can anyone help me out, btw this site kicks ass :SNSign:
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Oct 9, 2008
  • Oct 9, 2008
Have you looked at the top of the motor? It could be that one of the heater or EGR hoses popped off (both located on the passenger side). Just because its red doesn't mean its coming from a particular location... If there is rust in the coolant, it will come out with the coolant anywhere.
Also, I don't mean to point out the obvious, but... You can buy red engine coolant.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 9, 2008
  • Oct 9, 2008
yeah but this is a solid red not a translucent red, and after the water dried the red turned to clay in the driveway, and i also changed all the hoses checked them and nothing is leaking
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 9, 2008
  • Oct 9, 2008
ok i ran the engine again and it only looks to be coming out from behind the motormount but ill keep looking
A
aurdraco
11
Texas
Oct 9, 2008
  • Oct 9, 2008
I hope it's not a freeze plug, those are a nightmare to deal with. Rusted freezeplugs caused the death of my '89 5.0 after 160k miles.
Double check that it's not the heater core. Those tend to go out as well. If you have a wet front passenger carpet, it's the heater core. Keep your fingers crossed that it is that.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 9, 2008
  • Oct 9, 2008
i dont see how it could be the heater core there is no sign of moisture anywhere else in the engine bay or in the car, but if i need to replace it i'll just do it in car and in a couple weeks just pull the engine and rebuild it, its only one more thing to do to this car.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 10, 2008
  • Oct 10, 2008
ok update i went to put more coolant in it to find the leak and i poured the first gallon then the second gallon and kep adding fluid and realized it was pouring all over the ground underneath the car and this time it wasnt even running but is still dropping from that same spot at the motor mount can anyone PLEASE help me i need the car running by sunday to bleed and test the brakes/suspension
D
Deleted member 87397
Oct 10, 2008
  • Oct 10, 2008
If it's coming out by the motor mount and not out of any of your heater hoses, the drain on the firewall, the heater core, the radiator, any of the other hoses, or head gaskets, and it's down that low, it is probably 99% certain you have a bad freeze plug. which is no surprise given that the cooling system in your car has obviously not been taken care of by the previous owner. I can't think of anything else down in that area that would leak coolant but a freeze plug. Can you see the actual plug it might be or is it hidden behind the motor mount? get someone to lay under there with eye protection so they can see exactly where it's coming form while you are pouring. Make sure it's not trickling down from somewhere higher up.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 11, 2008
  • Oct 11, 2008
yeah i was underneath when seomone pouted it in i couldnt tell if it was coming from up top or not so im going to pull out the inner fender and check one more time to make sure its not coming out from behind the freeze plug cause thats really a pain in the ass spot to change it out
83T-top
45
#10
  • Oct 11, 2008
  • #10
If it's coming out as fast as it sounds, I would think it almost has to be a freeze plug. Cant you get up under it even it you can't see it, if you know basically where they are you should be able to get your hand in somewhere and feel it. Thats a pretty big hole to miss. I would pretty much guarantee that's what it is.
Beasty306GT
671
Oxford,Mass
Oct 11, 2008
#11
  • Oct 11, 2008
  • #11
Prob a freeze plug
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 11, 2008
#12
  • Oct 11, 2008
  • #12
unfortunatly i have very large hands so getting them anywhere to feel anything is a problem
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 12, 2008
#13
  • Oct 12, 2008
  • #13
ok new problem freeze plug is so corroded that i cant punch it out i hit it even slightly the punch goes threw so now i dont know what to do or how to get it out without pulling the engine
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 12, 2008
#14
  • Oct 12, 2008
  • #14
fixed....hole was about the size of a pencil little bastard was a pain in the ass to change
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
  • dan50
  • Jul 18, 2026
dan50
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
