5.0 project
  • Thread starter Thread starter outta phocus
  • Start date Start date Nov 13, 2012
O
outta phocus
  • Nov 13, 2012
It's been a while since I've been around the 5.0 and I am about to start a project and hoping some can help out with a few questions I have. I'm putting a 302 into a '98 M3 and the motor I have lined up is a '93 5.0 (stock block/cam), SN-95 Cobra heads and an Explorer intake.
I'll be swapping h/c/i, but what kind of power is the current setup good for?
Due to hood clearance issues, I'm looking for an intake with a similar height as the Explorer intake (I think I've seen a Trick Flow intake fit). With that in mind, what would be a decent h/c/i setup to get about 350whp on a stock bottom end and still be streetable? Is it possible to do this and keep the compression under 10:1 in case I throw on a s/c later?
Most everything I have read so far seems to point toward Trick Flow or AFR 185's and 1.6 rockers. Any help is greatly appreciated.
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Nov 13, 2012
  • Nov 13, 2012
Cobra heads and explorer intake will get you somewhere around 260-270 rwhp.. I would put a cam in to get the best out of the combo
O
outta phocus
  • Nov 13, 2012
Thanks for the suggestion. Any specific cam you would recommend for this application?
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Nov 13, 2012
  • Nov 13, 2012
I would just call any of the major cam companies and talk to one of their people. They will be able to recommend a good cam for your setup. I ran the stock 88 cam when I had that setup.. Should have gone aftermarket.. Upgrade the valve springs also.
O
outta phocus
  • Nov 13, 2012
Will do. Thanks
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
G
Engine PATS off pcm for 1999 Explorer 5.0 swap
  • GOvert
  • Dec 23, 2025
Fox 5.0 Mustang Tech Jun 14, 2026
GOvert
G
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
