@90sickfox @Noobz347 I don't have a scanner or an oscilloscope to be able to see what is happening as far as misfires go. Nor do I have a temperature gun which would have been another way to check each cylinder. I was relying on the DTCs posted by the pcm.
I don't have any experience with say for example, something like HP tuner that has the scanner features built in.
I have only seen the Holley systems advertised for sale and not in operation, but I would guess that they have the scanner feature built in.
Which DIS ignition are you referring to? Wasted spark or individual coil on or near plug? The 1999 to 2001 Explorer 5.0 uses a 2 wire camshaft position sensor that is compatible with the 1999 Crown Vic pcm. Earlier 5.0 Explorers had a 3-wire cam position sensor. (IIRC, you would need a 3-wire camshaft position sensor to use with the Holley system). The Explorer 5.0 has an all in 1 HB/damper/serpentine 36-1 crank pulley. It will only work with the Explorer front dress and no other 5.0 parts from earlier engines.
Explorer wasted spark pcms only have 4 coil drivers built in. Coil-near-plug pcms (like 1998 up 4.6 Crown Vics and 1999 and up 4.6 Mustangs) have 8 individual coil drivers built in their pcms. FoMoCo is notorious for making a system change a certain year on one particular model, but not on another so determining what changes were made year to year and model to model have to be determined individually.
@Noobs347 When I can finally get into working on my 2nd conversion, I will document all of it. This winter, I'm involved with 4 projects that are mostly bodywork majorly and somewhat simple old school engine/mechanicals so not much extremely interesting.
Hopefully in the spring I can get into the next c-n-p 5.0 conversion project. I've been collecting parts for now.
1996 to 2001 Explorer 5.0 hb/dampner/pulley/36-1 pictured below.
RA file photo below. I bought a new one while they are still available.
