dyb003 said:XE264? what is that? I dont realy tow anything beside my boat once in a blue moon. I use the Mark VII for that as the truck only seat two people and there is three of us.
I still want the lopy idle. So the F303 is not a good idea?
I have also heard that the rockers need to be shimed for replacement cams other than stock. This I did not do with the E303. Thinking I should now tho...
Will just doing this give me the little more power im looking for?
I have gotten mixed reviews on the cam choice.
Should I just leave the E303 in and shim the rockers and call it good for now untill i can get some good flowing heads? Thanks all
dyb003 said:I never did shim the rockers after I put in the E303. Can this be a problem? It does have a lopy idle but not that much. I have to turn the idle way down to like 600rpm's or so to get it, but then it on the edge of stalling, like if I turn the wheel sometimes it will stall. If I turn it up to like 900 or so it doesnt lop that much. So is this because of not shimming the rockers for the E303? thank you
I think you just need to find that "magic spot" where it will idle without stalling. When idle is up, lope will apear to go away. I personally don't think shim/no shim is an issue unless it just doesn't run right. Is it hitting on all cylinders, no matter what the idle is? Does it rattle? (ie rockers, lifter noise, etc..)dyb003 said:any thoughts on my last post? Thank you
dyb003 said:It runs just fine and on all cylinders. There is no rattleing noise. But what I dont know is that sence I didnt shim the rockers is it putting to much strees on the lifters or cam? There is a noise but its not a rattle or nocking, its more of just a rotateing noise that in more prominat after it worms up. It doesnt afect the way it runs, it just anoying. I took the belt off and its still there. Any thought on the noise?
