5.0 serges after it warms up
  • Thread starter Thread starter hairymetal
  • Start date Start date Jul 26, 2006
H
hairymetal
  • Jul 26, 2006
I have a problem with my 88 gt.When the car is cold it drives fine but after parking the car and then going out for a drive again the engine surges below 2,000 rpms.It seems to happen on hot days.It feels like vapour lock on old carburated cars.I put in a new fuel pump and filter and o2 sensors but it didnt solve the problem.Has anyone experienced this problem before?Anyone have any cures?The car is speed density,5 spd,off road pipes with flowmasters and headers.car has 100,000 miles on it...
HISSIN50
34
129
Jul 26, 2006
  • Jul 26, 2006
See Daggar's Technical thread index at the top of this sub-forum. Inside is Jrichker's surging checklist.
In my experience, SD stangs are very susceptible to the surging (and it's hard to get rid of).
Good luck.
Flavadave4
1,044
21
49
Utica, NY
Jul 26, 2006
  • Jul 26, 2006
yeah its a pretty common problem around here.
Do the check list and see where you get!
5.0_sleeper
47
  • Jul 26, 2006
Yeah, my sd car does the same thing. It will act like someone is in the car reving it, mine does it from 500 to 900 rpm's when it is warmed up. would like to know info to.
H
hairymetal
  • Jul 26, 2006
thanks for your resposes but maybe I didnt explain myself right.When I am driving the car on the highway at 1800 rpms in 4rth gear when the engine is hot the engine cuts out then comes back on.It jerks around.I end up shifting into 3rd gear and drive at 2800 rpm the problem goes away.I have had the car since new and it used to do it once or twice a year when the temperature outside was over 90 degrees.Nowdays it happens more often.Mostly when the engine soaks up heat.I was thinking maybe some component or fuel rail was getting hot and when I drove at a higher rpm fuel pressure would increase and cure the problem.The idle is fine on the car and always has been.
D
DeVus1
400
P-Town, Va.
Jul 27, 2006
  • Jul 27, 2006
Clean your throttle body, mass air meter, and EGR valve. Sounds like the computer is having a hard time reading the correct amount of air flow.
bill302
2,131
alabama,gadsden
Jul 27, 2006
  • Jul 27, 2006
when was the last tuneup...that would be the first step if its due for one..plugs and wires break down with heat ect...fuel filter clogged bad dist.cap,rotor if its due to be changed replace it and rule it out of the equasion and it may also clear it up.
HISSIN50
34
129
Jul 27, 2006
  • Jul 27, 2006
Your SD car doesnt have a functional CEL so pulling codes is a wise first step.
Good luck.
bradranger
50
Hollywood,Maryland
Jul 27, 2006
  • Jul 27, 2006
I have had the same problem with my car for a long time, runs fine on the first drive and then if I cut the car off and start it again it will run like crap. Hope to find an Answer soon. Good luck!
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
N
Resolved High idle when warmed up that slowly comes down over 2-5 seconds...
  • NooStang
  • Jun 30, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 3, 2024
NooStang
N
W
Resolved Loss of Horsepower After Base Idle Reset??
  • WTW
  • Aug 12, 2023
2K
Fox 5.0 Mustang Tech Aug 13, 2023
WTW
W
