- Jun 20, 2014
- 1
- 0
- 1
As I am a Diehard mustang and Ford fan, I chose to install a 5.0 into my Jeep Wrangler. I have a standalone painless harness and everything for a 93 5.0 except the mass air flow sensor for that specific year. everything is hooked up except the EGR.
It floods almost immediately on initial startup and then dies. If I disconnect the wire going to the fuel pump it will then start and run fine until it either runs out of gas or I tap the fuel pump wires together for a split second. fuel pressure is exactly correct and fuel pressure regulator is working fine.
The MAF I have is for a 96 Bronco because that is what I started with. I bought a BBK for that application and 24 lb injectors. the MAF is calibrated for the injectors. I have swapped the original injectors back in with the stock MAF and it does the same thing. Is there a difference in MAF's between years?
As far as I know that is the only thing different from the 1993 setup. every sensor is brand new. the distributor and coil are brand new. the computer is brand new. IAC and TPS are new. Engine is freshly built.
Please help me with any ideas you can.
Teddy
Teddy
