5.0 vacuum
  • Thread starter Thread starter titan85
  • Start date Start date Jan 12, 2012
titan85
  • Jan 12, 2012
new to owning mustang foxbodys, my question is i just b-cammed a 5.0 and went factory with everything else in the build. now the car sputters while rolling at any rpm.loads up and wants to shut off when stopping. I feel its a vacuum leak or one of my vacuum lines is in the wrong place. Also the timing is set at 14. helped alittle, not as bad on the fuel issue. After timing the car seems to have an idle surge, not a bad one only about 500rpm. I have searched some sites for diagrams on the vacuum harness but do not really understand what im looking at. any help would be appriciated.
titan85
  • Jan 30, 2012
fractured spark plug
Kdubslugga
1,515
Akron, OH
Jan 30, 2012
  • Jan 30, 2012
Is your car an AOD? They don't like cams. Also is your car a speed density car 87 - 88 or is it mass air equipped? 89-93
Reactions: titan85
5.0stang2191
  • Jan 30, 2012
My 86 Mustang seems to be having the same problems as titan85 . I have AOD transmission and its speed density. Now whenever I turn the car on or stop at a light the rpms go up and down and then the car just stalls. Could it be do to my car having e303 cam and cold air intake. I cleaned out the IAC and it still stalling when ever it idols.
Sorry titan85 now trying to steal your thread my car seems to be having the same issue.
Mustang5L5
Mod Dude
Feb 18, 2001
43,365
18,109
224
Massachusetts
Jan 31, 2012
  • Jan 31, 2012
Why guess? Run the check engine codes and then go from there
Sent from my iPhone 4S using Tapatalk
titan85
  • Jan 31, 2012
NO PROBS
titan85
  • Jan 31, 2012
WAS AN AOD NOW 5 SPD FOUND THE PLUG SATURDAY REPLACED, AND DELETED SOME OF THE OLD VACUUM LINES RUNS LIKE A DREAM
titan85
  • Jan 31, 2012
THANKS FOR YOUR GUYS HELP
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
