1995 mustang gt 5.0L automatic, car is high idle as 2k rmp and hang their, unplug MAF idle drop down perfectly but some time it back up to 2k and drop down 800rmp. While I unplug MAF it drive fine, but some time it idle spike again.
Here what I already do, no vacuum leak, clean and reinstall IAC, and replace the MAF sensor. Now either IAC or TPS is bad, I dont know how to pull code on this OBD I. Should I buy both IAC and TPS to try out see which one is bad ? thanks
, i put in new IAC and it fix the idle. car run good . and no jerking back and forth. and alot quiet now.
