5 lug axle differences???
EPIK
796
LEFT COAST
I am getting ready to do a 5 lug swap on my 91 & I had a few questions... I will be running 5 lug drums in the rear, for budget reasons & I wasnt sure if i could run some axles that I could get for a great deal. They are DutchMan 5 lug fox length axles & the previous owner said that he had ran Cobra rear brakes on them. I wouldnt be converting to rear disk for quite some time, so I need to know if these axles will work with drum rear brakes, or is there even a difference in axle types when it comes to rear brakes???
Thanks....
Also You should be able to measure them, Fox axles should be 29-3/16" ; Ranger: 29-5/32"; so if they measure up around there they should work.
I would also measure the 'hub' part on the axle and make sure they're the same or a close diameter.
Measure the axles and compare to the above.
If you want to run rear disks with the fox-lenght axles, look into North Race Cars rear disk brackets as the allow you to run SN95 GT, Cobra and fox t-bird brakes with stock lenght 4 and 5 lug axles.
Disks > Drums :)
Aerostar '86-91 Rear Axle; Ford, R.
Aerostar '92-97 Rear Axle; R.
Bronco II '84-90 Rear Axle; L.
Ranger '83 Rear Axle; 10 bolt hsg cover, L.
Ranger '84 Rear Axle; 10 bolt hsg cover, 7-1/2" ring gear, L.
Ranger '85-86 Rear Axle; 7-1/2" ring gear, L.
Ranger '87-92 Rear Axle; L.
Get two of these and buy new Ranger drums. Problem solved.
Thanks for the info guys...I want to go as cheap as possible, hence the reason I am gonna run drums for a while....I will eventually run SN95 Gt rear brakes because I still want to be able to run some 15" wheels for the track, but for now, new drums will work just fine.... I only asked about the Dutchman axles because I can get em for $50....
