5 lug conversion glich
  • Thread starter Thread starter jcb
  • Start date Start date Sep 26, 2011
J
jcb
9
  • Sep 26, 2011
ineed some more help i have 79 capri i put 8.8 rear end along with 5 lug axles that went great do to everyones advice moving on to front i used94 ball oints ,spindles and brakes got it almost together went to bolt up strut/shock top hole dosnt fit bought a striut for 94 but it seems to be to long does any one have any gidea what strut to use or a good remidie
ID89GT
1,659
18
49
Spokane Valley, WA
Sep 26, 2011
  • Sep 26, 2011
It should fit, I just did this on my 1980 Mustang using 95 spindles. Its a tight fit but the bolts will go in, if you have to gently tap it in with a hammer, just don't force it to much so you don't mess the threads up on the bolt. Also if you have to use a jack to move the lower control arm up to help line the holes up
J
jcb
9
  • Sep 26, 2011
thanks i figured it out i was sold struts for a 95 dont mount the same at the top 95 is to long
ID89GT
1,659
18
49
Spokane Valley, WA
Sep 26, 2011
  • Sep 26, 2011
The struts you had before you bought the 94 strut should have worked. I would see if you can swap the 94 strut for the correct one at the store
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Sep 26, 2011
  • Sep 26, 2011
Dont use 94-95 struts, use 87-93 struts. They feature a shorter body and won't bottom out.
You can even use your original struts provided you shim the strut with some hardened washers on the inside of the bolts to where the spindle mounting flange is
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Y
Resolved 5 lug conversion
  • Ybfav84
  • Dec 21, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2024
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
