5 lug conversion on a 86
I think you might have to change the spindle to 87-93. On my 85 i used ranger rotors on the front, but im not to sure about the 86. If i were you i would do a little research and figure out if the 86 has the same spindles as the 79-85. The easiest way to do it is use a pinto style spindle which works on the mustang. The pinto style spindle is used on modifieds on the circle track and has an assortment of aftermarket rotors and such. Look around on this site http://poske.com/index.htm
