5-lug ebrake question?? help please
  • Thread starter Thread starter old_blue
  • Start date Start date Jan 16, 2006
old_blue
1,783
282
124
Jan 16, 2006
  • Jan 16, 2006
I have heard many people make a special mod to their ebrake handle, welding and what not. Here is what I have, 96 axles, with 96-98 rear disc setup. I am going to go get the e brake lines I need from a FRPP dealership. I am curious if I need to mod my ebrake handle? I am also wondering if I need to worry about the brackets not working with the axle housing because it is the stock housing but longer axles and rear disc setup from that 96-98? or is the housing the same on the sn95 as the foxes? thanks in advance. Almost done putting this together and just need a few small bits and pieces (and front tires).
old_blue
1,783
282
124
Jan 16, 2006
  • Jan 16, 2006
after writing this I did find one post that explains it better, been searching for awhile now. I guess no matter what I am going to have to modify the handle which isn't a problem from what I have seen. I am more curious now with the brackets not fitting for whatever reason. Maybe I am just being paranoid.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jan 17, 2006
  • Jan 17, 2006
Yes you have to mod your brake handle, its no big deal and you can find the instructions on the Ford Racing web site under the M2300K Cobra Brake Kit. As long as you used parts from the rear of 94-98 you will be fine the axle housing is the same width as the stock Fox, the Brackets make up the extra width thus the 3/4" longer axles. Good Luck with your project!
old_blue
1,783
282
124
Jan 17, 2006
  • Jan 17, 2006
thanks, I thought I would be ok but I just don't want to get down to taking it all apart only to put it back together again as a 4lug LOL
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jan 18, 2006
  • Jan 18, 2006
No Problem, you are ok as long as your parts came from a 94-98 for the rear. Make sure the Caliper Brackets and the Anti-moan Brackets come from the same car though because sometimes they will not match up with each other.
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
