5 Lug Help!!!
  • Thread starter Thread starter 1FaStMcLAREN
  • Start date Start date Jul 16, 2005
1FaStMcLAREN
Baldwin Park, Ca
Jul 16, 2005
  • Jul 16, 2005
hey everybody, i need some help getting my 4 lug fox into a 5 lug conversion. For all of you out there that have done it, if im not mistaking the front rotors i could get off a lincol mark VII right? what about the drums, off of what car/truck should i get them of? Also, what axles would fit for the back, i've been told i have to use two different ones from two different cars, but then again, im not sure at all.
thanks everybody!!
any other tips while doing the 5 lug conversion?
Mavrick
2,264
Collingwood, ON
Jul 16, 2005
  • Jul 16, 2005
http://svo73mm.cjb.net - This place has all your answers!
trbkrb
1,976
Houston, TX
Jul 16, 2005
  • Jul 16, 2005
#1 question to answer before planning your conversion: What wheels do you want to run? Many wheels will not work with the Mark VII rotors and require the 94+ conversion.
#2 question: Do you want to improve the brakes or just continue with the marginal Fox brakes? This is an excellent opportunity to upgrade the safety side of your car with the 99+ calipers or Cobra brakes.
Read Matt's site listed above above. He has almost all the options and answers.
Good luck!
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Jul 16, 2005
  • Jul 16, 2005
Cheapest way is the lincoln rotors and the $199 Ford Motorsport axle and drum kit. You can potentially do it for around $250.
Won't improve stopping power though.
A sn95 disc setup costs considerbly more, probably $800-$1000, so go with your budget. Some will say around $500, but that's just luck in finding someone to rid of parts that cheap.
9
92BlackGT
182
Tinker AFB, OK
Jul 16, 2005
  • Jul 16, 2005
go with the sn95 spindles up front so you can run Cobra brakes and convert to rear disc....brakes feel so much better when you have to hit the brakes hard going 85....you actually slow down.
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
