5 lug spindle question
  • Thread starter Thread starter Roland69
  • Start date Start date Jul 22, 2007
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 22, 2007
  • Jul 22, 2007
I have the chance to buy spindles, calipers, wheel bearings for my car to do a 5 lug setup....but the parts are from a 2000 Mustang. will this all work the same as any other 94-98 setup. The calipers are aluminum he says so that would be a bonus
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Jul 22, 2007
  • Jul 22, 2007
everything ive seen says the 99+ spindles are the same as the 96-98's. id do the deal just for the calipers if theyre in good shape, probably the best brake setup for a junkyard 5-lug swap that can still fit a 15" drag wheel.
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Jul 22, 2007
  • Jul 22, 2007
You have to swap to a later style ball joint or use a spacer with the fox ball joint..
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,120
224
Massachusetts
Jul 22, 2007
  • Jul 22, 2007
1996-2004 all use the same spindle. It's slightly wider than the 1994-1995 version and both are slightly wider than a Fox spindle.
The 96+ units offer better suspension geometry and bumpsteer.
The calipers are twin-piston PBR calipers with dual 44.5mm pistons and a 10.8" rotor. About the best performance you will get without going to a 13" cobra rotor.
onefstsnake
792
Northern VA
Jul 22, 2007
  • Jul 22, 2007
and the PBR's are Aluminum and probably half the weight of stock calipers.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 22, 2007
  • Jul 22, 2007
cool so I should probly get theese then. and all I have to do is use ball joints for a say 2000
onefstsnake
792
Northern VA
Jul 23, 2007
  • Jul 23, 2007
any 96+ ball joint should work.
Pick up some SS Braided lines while your at it.
Chuckman
1,604
1,002
173
st. louis, mo
Jul 23, 2007
  • Jul 23, 2007
or a spacer on the threads, the only real difference between the fox and sn balljoints is the length of thread on the stud, as the fox spindle castings are thicker in that area.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,120
224
Massachusetts
Jul 23, 2007
  • Jul 23, 2007
All sn95 ball joints are the same.
If you pick up the steeda x2 balljoints, they have a grease fitting to lub them up. Worth it in my opinion. Quiet suspensions rock
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
