5 lug spindle question
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
I have the chance to buy spindles, calipers, wheel bearings for my car to do a 5 lug setup....but the parts are from a 2000 Mustang. will this all work the same as any other 94-98 setup. The calipers are aluminum he says so that would be a bonus
everything ive seen says the 99+ spindles are the same as the 96-98's. id do the deal just for the calipers if theyre in good shape, probably the best brake setup for a junkyard 5-lug swap that can still fit a 15" drag wheel.
1996-2004 all use the same spindle. It's slightly wider than the 1994-1995 version and both are slightly wider than a Fox spindle.
The 96+ units offer better suspension geometry and bumpsteer.
The calipers are twin-piston PBR calipers with dual 44.5mm pistons and a 10.8" rotor. About the best performance you will get without going to a 13" cobra rotor.
