Can I get 500 hp NA out of my 03 GT? If so what would I need to do? I assume a 5.1 Stroker would be the start. It has to run on 91 octane by the way.
00s281sc368 said:500HP N/A means 110HP/liter...
Smaller blocs like the M3 or S2000 get that, but that's also with a 8000rpm or 9000rpm red line... higher compression and 4V/cyl of course...
I get the same 110HP/liter at only 6000rpm with my stock 4.6 2V block and the help of little boostnot to mention the higher torque all the time!
Just stick with you plan B and get boost !
ponysarepretty said:A curious thing is if your power were to peak at 6000 RPM and the Honda were to peak at 9000 RPM, you would have to make 50% force (ie torque) to have the same amout of power as at 9000 RPM.
At 10500 RPM, if you had a 300 lb/ft motor, it would be making 600 hp there![]()
97gtblue said:hey hotmustang, what kind of power is your built 331 makeing i have a freind with one and he ran a 450 to the wheels mustang and ran with him...the 331 was on all motor...
like everyone said it would take alot of cash to do that if it is possible
. The guy said that there was so much left on the table with the tune and exhaust that I could get another 70RWHP out of it EASY. It had 2 1/2 inch exhaust into an H and then into some 3 chambered deltaflows, then went out of the flows with 2 1/4 NON mandrel bent pipe (after we cut it out...it got down to around 1 1/2-3/4 ish ID in some of the bends
) out the back. A/F was at around 10.5 lol. Needless to say im going to buy a wideband 02 w/ gauge, in car timing adjuster ( dont even know what kind of timing its running now...but it will run 87 lol), and a jet kit and have at it. As you can see, it was NO where near refined when dynoed. It should make 340-360ish when we are done.
. The thing that worrys me thoug about teh dyno is that it only made 216RWTQ
...I really dont trust the owner, so I dont know if the dyno was tampered with. Oh, and the car weighs 2890LBs so was still darn fast even with only that much power....cant wait to see how its going to run now
and we also took off the flex fan and put on an electric fan and replaced the mechanical fuel pump with an electric one (still in process). Sorry for the length, but I needed to explain what was going on then vs now.Torinalth said:i have talked to VT engines and from what they told me, going with their 324 (thats their 3.7 bore and 3.75 stroke block) at an 11:1 (still usable on 93 octane). with their stage 2 cams, fully ported heads, full intake and exhaust; when tuned you should be around 475. so, take it for what its worth. but maybe lighten the drive line (aluminum FW, CF drive shaft) and you should be able to get close with a well performed tune. on a side note they did say they could alter the build slightly to see an 8000 RPM redline.
just wanted to pass along toms knowledge that was handed down to me.
EDIT: on a side note... you do realise that the cost of this is just slighly more then the KB... you get the power, AND a built block though.... VTs recommendation on this block was the spray the hell out of it (their exact words) to get whatever more power you wanted..... NOS direct port anyone?
Torinalth
Torinalth
