AXIStang said:
Wow that is a great 60' already. What kind of drivetrain are you running. Those are some nice NA number congrads.
Here's the whole setup:
Engine/Fuel/Cooling – D.S.S. Pro Bullet 306 with H-beam rods, Brodix Track 1 Heads CNCed by M2 Race Systems, Anderson Ford N-71 Camshaft, Jesel Sportsman Series Shaft Rocker System, Holley Systemax intake, Phenolic Spacer, ATI Balancer, Accufab 75mm Race Style TB and EGR spacer. Holley 255 In-tank fuel pump, #8 AN Fuel line from custom In-tank pump to split factory rails, 30# Injectors, Crane Adjustable FPR. FMS Radiator, Edelbrock Water Pump, Flex-A-Lite Electric Fan. Downs Ford Mass-Air Conversion Harness, Pro-M 80 MAF, Anderson NA Power Pipe, Dyna-Batt 13 lb. Battery. Mac Long tubes, Mac Off-Road H-Pipe, FlowMaster 2-Chamber Cat-back, Mini-Starter.
Trans & Rear – G-Force T-5, Pro-5.0 Shifter, Hurst T-handle w/button. SPEC Aluminum Flywheel, SPEC Stage 3 Clutch, Shark Adjustable Clutch Cable and Firewall Adjuster, McLeod Scattershield, FMS Aluminum Drive-shaft, Lakewood Safety Loop, 4.10s, Moser 31-spline axles, Moser C-clip eliminators, Spool, Downs Ford Girdle.
Suspension – Competition Engineering Sub-frame connectors, Steeda Front Drag-Bar, D&D Motorsports Tubular K-member, UPR Chromoly A-Arms and Coil-Over conversion including Hal springs, Maximum Motorsports Caster/Camber plates and Strut Tower brace. Koni Adjustable Struts, Flaming River Manual Steering Rack & Steering Shaft. D&D Motorsports Adj. Upper Control Arms, Metco Lower Control Arms, Eibach Drag Launch Springs, Hal 12-way Adj. Shocks, Wolfe RaceCraft Anti-roll bar. Wild Rides Battle Boxes Upper and Lower. Torque boxes welded.
Electronics/Gauges – Anderson Ford PMS, MSD 6AL, MSD Distributor, MSD Balster 2 Coil, MSD Plug Wires, MSD 2-Step, MSD RPM Selector, MSD Shift Light. Autometer Phantom Gauges - Playback Tach, Boost, A/F Ratio, Fuel Pressure, Oil Pressure, and Water Temp. Line Lock.
Drag Gear – Wild Rides 8 point bar, Comp Eng Swing-Outs, Weld Draglites, Hoosier Skinny fronts, M/T 26 *10 ET Drags, Simpson Helmet, Fire Jacket, and 5-Point harness.
