What does it all include usually? Spark Plugs replaced? Manual transmission fluid? etc. And how much of it could I do by myself? I am a novice, but I have some good tools and can follow directions (i'm married)
Give us an idea of things you have attempted/done on any car, such as oil change, oil filter change, brake pad replacement.
Do you have a convenient place available to do the work?
Do you have access to a torque wrench?
Do you have low (3" - 6" high) drive-on ramps or some other convenient way to safely raise the front or rear end?
Well I have Rhino Ramps to jack up the front end. I have done Oil Changes, and that's about it. hahaha I would like to learn more, I have a big garage to work on it. I dont have a jack or jackstands yet...I have done some electrical work wiring etc... also
At the ford dealership i work at, 60k includes battery test, fuel filter and air filter replacement, flush and fill radiator, change oil, check/set tire pressure, rotate tires and anything else that may need to be replaced or checked.
I would throw in "change the spark plug wires" as well, while your changing the spark plugs. And maybe run some Fuel Injector Cleaner through the system.
