Hi all, I was hoping to get a little advice from the group as I searched and did not find...so here goes.
I have a 65 coupe with a 289 and other than the Edelbrock carb and intake dual exhaust, and electric fan it's pretty much stock. It was rebuilt somewhere around 5000 miles ago and has a rebuilt C4 bolted on the back of it.
My problem is that it will bog down and die shortly after gaining speed on the highway. It also does this after cruising at 50 or 55 for about 20 minutes or so. Once the car is put in park or neutral, the problem goes away. I've noticed a lot of gushing going through the fuel filter when it happens, but I can't tell if it's boiling or just getting pushed around because it's messing up. But let me tell you what I've done so far to try and fix it:
Brand new Edelbrock 500 cfm carburetor (had same problem with Holley 4150)
Ran new fuel lines from fuel pump
New fuel filter
New battery (unrelated)
Wired electric fan to run all the time (temp. sensor broke anyway)
And some other things I'm sure I'm forgetting. I know there isn't an internal vacuum leak and don't see how I could have an external one. Let me tell you what my next guesses are:
1) Overheating transmission
2) Vapor lock
3) Screen in fuel tank getting sucked into the line
4) Bad fuel pump
5) Bad thermostat
Any suggestions/comments/other guidance would be greatly appreciated. I'm trying to get the car (my daily driver) to work and I'm coming on the end of the semester very quickly. Thanks in advance!
New fuel filter
2) Vapor lock
4) Bad fuel pump
5) Bad thermostat
