65 Frame rail help
  • Thread starter Thread starter 65fastbackresto
  • Start date Start date Apr 18, 2007
65fastbackresto
1,229
AR
Apr 18, 2007
  • Apr 18, 2007
My 65 fastback has some rust in the frame rails, being as I`m installing a V-8 from a 6 cyl, I think I need to add some steel to the rails. We are gonna cut out the rust and put new steel in its place.:SNSign:
We are adding subframe connectors and we have cut some 1/4 inch steel plate to weld onto the existing frame rails, has anyone out there tried this? What do I need to watch out for, I`m not a welder, but my buddy doing it is, we are using a mig welder.
BlackGMC
247
  • Apr 18, 2007
In my opinion 1/4 is way to thick and I would go with 1/8.
65fastbackresto
1,229
AR
Apr 18, 2007
  • Apr 18, 2007
Black GMC
I`ve got some 3/16 thick steel too, just in case.
BlackGMC
247
  • Apr 18, 2007
3/16 would be better than 1/4 and easier to weld and get pentration. Do you have pics so people can advise better?
351w_swap
263
  • Apr 18, 2007
I did this my first time around, the original is really only 16 ga or at most 14 ga. Dont use the quarter inch, weld in some 16ga. menards sells it and it is much more workable. for 8 bucks you can have enough to patch all your rust spots. I have done it to my car and my uncles jeep both with great results.
CraigMBA
783
Orange, CA
Apr 19, 2007
  • Apr 19, 2007
C
C6AE
145
Ma.
Apr 19, 2007
  • Apr 19, 2007
All those pieces are available, do it right the first time...
If you don't want to change out the whole framerail (recommended) buy a replacement and only use what you need. I think this would look much nicer than 1/4" plate
65fastbackresto
1,229
AR
Apr 20, 2007
  • Apr 20, 2007
I dont have pics yet
We are going to slice the bad out and put the heavier steel up into the frame rail and weld it in, it will look like it does now, but more meat in the rails so to speak.
I lost the cord to my computer from the camera, so cant get pics yet, but soon I will be able to.
The rust is under the front floorpans on the rails just before they start up the firewall. Its mainly on the bottom of the rails facing the road. The welder said cut the bad out and either put in new plate or fill it in with the mig welder (440 Volt monster welder).
Thanks guys.
65fastbackresto
1,229
AR
Apr 22, 2007
  • Apr 22, 2007
Frame rails are fixed.
They look awesome, you`d have to look REAL close to even know they`ve been welded, only place you can even see the welds is laying under the car from the tranny tunnel. We stuck on the subframe connectors though, one side went fine, couldn`t get the eye bolt outta one side, its stuck.....
351w_swap
263
#10
  • Apr 22, 2007
  • #10
where are the pictures? Most of us aren't good at imagining.
65fastbackresto
1,229
AR
Apr 22, 2007
#11
  • Apr 22, 2007
  • #11
Pics real soon
We are going to radio shack today to get the cord for the digital camera.
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
Frame rail strut tower repair
  • Creomod
  • Dec 5, 2024
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Creomod
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
T
Greetings from a guy who needs help with a foxbody.
  • thefonztm
  • Mar 21, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2026
R
Paint and Body Front frame dimensions
  • rookie7112
  • Sep 15, 2024
Fox 5.0 Mustang Tech Sep 24, 2024
90sickfox
