65 gauge cluster removal...
  • Thread starter Thread starter 6FIVE_STANG
  • Start date Start date Feb 24, 2007
6FIVE_STANG
142
San Jose, CA
Feb 24, 2007
  • Feb 24, 2007
i took all 8 screws out and was able to tilt it downwars a little bit but thats it. i have about a 2inch gap. from this gap i seen a thick black cable thats connected to the back of my cluster. the only problem is, is that i cant reach it!! what else can i do?
65Stang200
40
  • Feb 24, 2007
Wiggle it up and down. That long black cable is your speedometer. You have 2 options, you can disconnect it at the tranny (easiest) and it will move forward, or you can reach way back with a wrench and try your luck at removing it from the back of the cluster. It will come right out. =D
6FIVE_STANG
142
San Jose, CA
Feb 24, 2007
  • Feb 24, 2007
what do you mean by that??
...and where exactly on the tranny is it located?
65Stang200
40
  • Feb 24, 2007
It's in the tailshaft of the transmission. It's 1 7/16 bolt that holds it in, I think. You'll see the cable going into the tailshaft of the transmission. Pull that bolt and tab out, pull straight out on the cable, and the speedo gear will pull right out.
DissFigured
320
Dallas, TX
Feb 24, 2007
  • Feb 24, 2007
I had the same issue when rewiring my dash.
I was able to reach my arm up under the dash by laying on my back with my head in the floor and reaching up behing the cluster and unscrewing the speedo cable by hand from the cluster.
M
mustangman1974
463
  • Feb 24, 2007
take your steering wheel off you will be able to get in there better.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • dan50
  • Jul 18, 2026
dan50
