i have a 65 mustang with a 302 & AOD trans. I want to know if i buy a stock replacement exhaust system will it fit? I know the AOD is bigger but i don't know if it will clear it or not. Thanks
im going to say no, only because the aod pan is much wider than the c4... if you are going to the duals with the h pipe, you can probibly use the intermediate pipes, (from the h pipe to the mufflers), and the tail pipes, and have the pipes from your manifolds to the intermediate bent up locally.
