65 mustang with a post 1970 289
IGN65
9
I have a '65 Mustang with a post 1970 289 transplanted in to it. The water pump lower hose was on the drivers side. I replaced it with a passengers side type pump. I then had to replace the crank pulley. Now the v belt does not line up properly. Have any of you had this problem? I really don't want to have a special water pump pulley made.
if it is a late 68 or newer motor it will be a 302 ,289 was droped in early 68
is it a 4 bolt crank pully? motor sport makes a set of aluminum pullies that should fit
I thought so as well. Ford produced the 289 until 1977 and were used in several platforms. Most likely, this motor is a truck motor.
if you can take off a valve cover, in between the valves you will see either
289,302 or 351. look above the starter on the block you will see a part # start of # is the year C4- C9. C4 is 64 ,C9 would be 69 the C standing for 60s .D would stand for 70s so D7 would be 77. E would be 80s and so on
