  • 1994 - 1995 Specific Tech
6500....yikes
  • Thread starter Thread starter fiveoho
  • Start date Start date Oct 15, 2006
1 of 2 Next Last
fiveoho
1,958
TN
Oct 15, 2006
  • Oct 15, 2006
4.10s and a hypertech use with caution
well the car revs a whole lot faster with those 4.10s and im assuming the hypertech eliminated the factory rev limiter. i was playing earlier and looked down from my 1 - 2 shift and it was sitting on 6500. it was there for a split second. i know i probably didnt hurt anything but it would make me feel better if you guys agreed with me. there arent any strange knocks or pings and its not smoking. ive never reved it that high and didnt mean to.
nothin to worry about?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 15, 2006
  • Oct 15, 2006
You did no harm, 6500 isn't high. Just way out of the powerband of a bolt on car.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 15, 2006
  • Oct 15, 2006
The bottom end could probably handle a little more, though I wouldn't want to be the one to test it. You probably floated your valves a little on that one, but you should be alright.
fiveoho
1,958
TN
Oct 15, 2006
  • Oct 15, 2006
so im ok, phew
just makes me nervous.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 15, 2006
  • Oct 15, 2006
Yeah the bottom end wll be fine, 6500 is just tickling it lol. The valve springs though did NOT like that. But you have afr 185's listed in your up comming mods so it doesn't matter.
fiveoho
1,958
TN
Oct 15, 2006
  • Oct 15, 2006
still stuck with the stockers right now
Adam95GT
2,564
Burlington, NJ
Oct 15, 2006
  • Oct 15, 2006
your almost exactly like i was with my probe... after i ut in the KLZE and a new clutch annd a light weight fly wheel... i also decided to gutt the back end out of it... SOOOOOO the car reved quick as hell... a civic came up along side of me and started to rev... i revved back civic went hard as did i i didnt reallize how quick first went by and i was sitting on 7700 rpms.... shifted to second and torque steered almost in to the median.... well at least i smoked the civic.... lol.... The klze floats valves past 7000 RPMS so i was in the DANGER ZONE!
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 15, 2006
  • Oct 15, 2006
It will just pump up the lifters and might run rough for a while
besides
If you were looking at a stock tach ............
Most likely was not 6500
Grady
fiveoho
1,958
TN
Oct 15, 2006
  • Oct 15, 2006
besides
Grady
this is probably true. just as long as i was turning less rpm and not more rpm than i was showing
Z
zZsKyZz
503
Oct 15, 2006
#10
  • Oct 15, 2006
  • #10
Why did you take the rpm limiter off? If anything, I would just raise it if need be.
It's there for a reason.
fiveoho
1,958
TN
Oct 16, 2006
#11
  • Oct 16, 2006
  • #11
didnt take it off purposely. i know its there for a reason, im aware of that.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 16, 2006
#12
  • Oct 16, 2006
  • #12
Just a tid bit of info
If you be a stick GT kinda guy
and
gotta good bit of miles on the clock
The tired valve springs will limit things before the pcm
btw ... the auto Stangs have a good bit lower limit
Grady
95Vert
1,785
North Mexico (deep south Texas)
Oct 16, 2006
#13
  • Oct 16, 2006
  • #13
I've hit 7k a couple of times, compliments of Paul, but I have new springs and rockers. You should be fine as long as you don't get on it ALL the time.
Labora
1,855
26
69
Dallas, Texas
Oct 16, 2006
#14
  • Oct 16, 2006
  • #14
Get a shift light and ignore the stock tach...Here is a vid of my tach.
http://youtube.com/watch?v=ZFJXeGVCmkA0
My light is set at 5800RPM. Just to give you a clue how far off the stock tachs are they read pretty slow....
BTW I wouldn't write off your rev limiter not being turned on still. I've spun the needle on my tach well off the red zone...
fiveoho
1,958
TN
Oct 16, 2006
#15
  • Oct 16, 2006
  • #15
shift light...good idea.
i know the factory tach is off, but maybe its more off than i think? maybe i freaked about hitting 6500 when maybe i didnt?
Labora
1,855
26
69
Dallas, Texas
Oct 16, 2006
#16
  • Oct 16, 2006
  • #16
They are way off I hit 7k~ every shift (on that video) but the light comes on @ 5800 per the ECM signal. I didn't do it in the video but I've done it while on the autox course. I've spun the tach all the way past the 7k mark it was pointed at 6 oclock almost. First time I did that I thought I didn't have a limiter either...(but my car does)
fiveoho
1,958
TN
Oct 16, 2006
#17
  • Oct 16, 2006
  • #17
i can put just a shift light on a factory ignition , right? even with no aftermarket tach?
how hard to hook up?
Labora
1,855
26
69
Dallas, Texas
Oct 16, 2006
#18
  • Oct 16, 2006
  • #18
If you get the "raptor shift light" it is as simple as 1 wire for tach, 1 power, 1 ground. Pretty easy that is what I have.
fiveoho
1,958
TN
Oct 16, 2006
#19
  • Oct 16, 2006
  • #19
sweet. i appreciate it man
Adam95GT
2,564
Burlington, NJ
Oct 16, 2006
#20
  • Oct 16, 2006
  • #20
my probe was like 700 - 800 RPM off on the stock tach... just throw in an automeeter... best mod to my driving ever... hit shifts dead on... track times got quicker
1 of 2 Next Last
fuel and timing issues anddd HOLYYYY TOLUENEE BATMAN!!!!
  • BLCK95GT
  • May 6, 2010
2K
1994 - 1995 Specific Tech May 7, 2010
rj95svt
Went to look at a mustang today...
  • tannerc91gt
  • Jun 1, 2010
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2010
Cobra912
where to buy a rev limiter?
  • fiveoho
  • Oct 3, 2006
1994 - 1995 Specific Tech Oct 3, 2006
WhiteDevil
Unusual Timing issues - could I have the distributor out 180?
  • Chythar
  • Nov 18, 2007
2K
1994 - 1995 Specific Tech Dec 5, 2007
WHITE94COBRA
M90 root blower how to info
  • 1987LXragtop
  • Jan 7, 2011
  • SN95 V6 Mustang Tech
9K
SN95 V6 Mustang Tech Jan 7, 2011
1987LXragtop
