66 conv. 302 5 speed 8" rear
  • Thread starter Thread starter sdsteve619
  • Start date Start date Sep 24, 2011
sdsteve619
43
Orem, Utah
Sep 24, 2011
  • Sep 24, 2011
Why not beef up an eight inch rear? How much would it cost to add a posi unit and change gear ratio? i'm new to this and it seam so much trouble to use a 9/8.8 inch. Thanks for your help.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Sep 24, 2011
  • Sep 24, 2011
Good call. There are 8" 4-pinion Traction-Lok units available now that are stronger than some 9" rears.
iskwezm
4,159
20
79
Rowland Heights,California
Sep 24, 2011
  • Sep 24, 2011
i built my 8" about 15 years ago with a Currie 4 pinion TSD and billet side cover and its taken A LOT of abuse.
blueovalnotch65
17
  • Sep 24, 2011
I built my 8" about 7 years ago with a Detroit Tru-Trac and it too has been through a lot with no issues.
chris66dad
167
Benicia California
Sep 24, 2011
  • Sep 24, 2011
You can buy a center chunk with custom gears and trac loc for around $800.
They are good for 550 HP.
You should also change out the axle bearings and seals for another $100 in parts and labor
http://stores.ebay.com/8-AND-9-INCH-FORD-REARS-TJ1141?_trksid=p4340.l2563
Realmongo
I prefer to be called "Evil Genius"
2,468
86
99
Western Mass
Sep 24, 2011
  • Sep 24, 2011
X2 for the Detroit Tru-Trac with 3.25:1 Motive Gears.
Vinyl66
398
  • Sep 26, 2011
I'm with the others. Detroit locker and 3.55 gears in my 8" rear with many dragstrip passes deep into the 11's. Still going strong.
65fastbackresto
1,229
AR
Sep 26, 2011
  • Sep 26, 2011
I also had my 8 inch rear built.
I took it to an offroad shop where they work on 4 wheel drives alot. Cost me $1100 for a 355 posi that has also been beat up alot.
I have a buddy thats had an 8inch rear in a strip car with drag slicks on it for 20 years, these things are pretty tough.
Oh, I just noticed your running a 5 speed, I`d go either 390 or 411 gear ratio with that tranny, if I could reverse mine and do it over, thats what I would do, the 355 I have is too low, I cant shift into 5th gear till about 70 mph.
sdsteve619
43
Orem, Utah
Sep 26, 2011
  • Sep 26, 2011
Thanks for all the help. I thinl I'll go with D.L. and new axles.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
