66 Door/Window alignment help
  • Thread starter Thread starter xoxbxfx
  • Start date Start date Oct 6, 2008
xoxbxfx
3,959
Southlake, TX
Oct 6, 2008
  • Oct 6, 2008
For some reason the drivers door window doesnt line up correctly. It is pushed out about 1/4" and doesnt seal on the upper weatherstrip. Anyone know how to fix this? These are original doors. The passenger side fit like a charm. The rear 1/4 window on the drivers side is fine as well.
I thought the upper part of the door needed to be adjusted at the hinges. but no luck there.
Im guessing I need to adjust the upper stop on the window as well...it is down just a bit. Even pushing the glass up all the way doesnt solve the weatherstrip problem. It is angled out.
enferno
418
  • Oct 6, 2008
there will be 2 stops that effect the height of the window in the front and one in the back.
you will also need to loosen the rear window guide and angle it so the window is angled correctly. if you open the door and look at the side where the VIN is, there should be some caps to pop off to loosen/tighten some nuts and then you can shift it. the top cap should give you access to the top stop, using a nut and an allen wrench
jb1dsl
566
Marianna, Fl.
Oct 6, 2008
  • Oct 6, 2008
Im glad you asked I need to adjust mine up about a 1/4 of an inch on the drivers side to.
Did you shave the rails??? It looks like it exposed alot of the seal and roof edge
xoxbxfx
3,959
Southlake, TX
Oct 6, 2008
  • Oct 6, 2008
yep...drip rails are shaved. They are still pretty rough, it needs a lot of bodywork. It should be fine as long as the window seals.
R
Door Ajar issue
  • ryjack70ss
  • Jul 25, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jul 25, 2025
Paint and Body Driver door alignment
  • elarm1
  • Mar 23, 2025
Fox 5.0 Mustang Tech Mar 24, 2025
elarm1
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
J
Adjustment of driver front door
  • JJHstang
  • Feb 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Mar 2, 2025
89ripper
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
