66 steering wheel removal
  • Thread starter Thread starter fastaggie
  • Start date Start date Jun 11, 2005
F
fastaggie
21
Houston
Jun 11, 2005
  • Jun 11, 2005
Guys, sorry for this post but this thing is kicking my butt. I've been outside in the Houston heat and humidity for the last 2 hours trying to get this wheel off. It's the deep dish simulated wood wheel with the three horn buttons on the spokes. I've got the nut off but where do I attach the puller? I've already bent the thin steel plate immediately underneath the nut. HELP!!!!!!!!
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jun 11, 2005
  • Jun 11, 2005
What type of puller are you trying to use????
A steering wheel puller or a harmonic balancer puller work well.
There are 2 threaded holes on either side of the centershaft of the steering wheel. You are supposed to thread bolts into them and tighten the puller bolt agains the centershaft to remove the wheel.
Puller needed: http://www.autobarn.net/cta1512l.html
See puller in operation:
http://www.film.queensu.ca/CJ3B/Tech/SteeringWheel.html
F
fastaggie
21
Houston
Jun 11, 2005
  • Jun 11, 2005
Dennis, thanks for quick reply. I was back with the car. I was not using correct puller. Hadn't noticed holes. Do you have any idea what thread they are? I've tried several sizes but to no avail. I suspect the threads are messed up so if I can find out what they are I'll chase them. Thanks.
A
a.vannoy
90
  • Jun 12, 2005
Heres a quick way to do it without the puller, brace you knees up under the steering wheel and put pressure on it at same time, then give it a quick thump underneath with both hands...allways works for me.
dennis112
1,561
36
79
Jun 12, 2005
  • Jun 12, 2005
They are good ole SAE (not metric). The exact size I am not sure of BUT I believe that they are "fine" threaded.
I've had mixed results using a.van's method, but you could try that too.
L
limey66
408
Northampton, England
Jun 12, 2005
  • Jun 12, 2005
If you're going to try this method, make sure you spin the retaining nut on a turn or two, to stop the 'wheel smacking you in the face when it pops off.
Unless you want to look like a boxer...
G
1986 Horn Button 2 Spoke Steering Wheel
  • Glane
  • Apr 18, 2019
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2019
95BlueStallion
H
67 Steering Wheel Horn Problem
  • Hankismyname
  • Nov 23, 2017
2K
Classic Mustang Specific Tech Nov 23, 2017
horse sence
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
K
Removing Steering Wheel On My 85 Svo
  • KENNY sTEVENSON
  • Jan 3, 2017
3K
Fox 5.0 Mustang Tech Jan 22, 2017
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
