68 289 More Power!
  • Thread starter Thread starter 6mustang8
  • Start date Start date Sep 27, 2008
6mustang8
  • Sep 27, 2008
I've driven a 68 289 2v stock engine for awhile and finally have some cash to upgrade a few things. I don't want to go wild but I'm looking for more power and a great sound. Its a 1968 with A/C and power steering (info for headers). On the intake I was thinking of a 570 cfm street avenger on a weiand stealth. For the exhaust I want to change the the manifold w/ single exhaust to something like Dougs tri-y's to an H - dual exhaust with dynamax muff's. I was thinking 2 1/4" would be plenty for this set-up. Does this sound right for intake and exhaust to match? Will the power steering or A/C cause problems for the headers? BTW I'm not planning on doing any mods to the engine itself, just the add-ons. I'm fairly new to this so any help would be great!
Thanks
68conv4sp
270
  • Sep 27, 2008
I had essentially the same motor. The 68 has 63cc combustion chambers, thus low compression - 8.7:1. I did the extrnal mods you have described with little effect. Then I added a moderate cam (Crane w/ .469 lift) and alum edelbrock heads (60 cc). That made a HUGE difference. So, as a package i have tri-ys, 570 Avenger, cam and heads. The Tremec 5 speed and 3.55 diff capitalize on the mods, and the tires will spin in second. Its like being in high school w/ the car I always wanted. My only second guess is that I should have stuck with the Edel 500 cfm carb. It was smoother at low rpms, and only slightly weaker at the top end.
D
D.Hearne
11,730
south louisiana
Sep 28, 2008
  • Sep 28, 2008
Thanks
Do just what mods you listed and then add a Comp Cams 268H cam, new lifters and valve springs(if you've still got the originals on the heads, otherwise if the springs are fairly new, leave em be) The 268H will compliment the compression ratio.
S-Car-Go
332
San Jose, CA
Sep 28, 2008
  • Sep 28, 2008
Sounds like a good plan, but what trans and gears do you have?
6mustang8
  • Sep 28, 2008
Everything is original to the car: C4 transmisison with 2.79 axle ratio. 8.7:1 Compression. I just now have $$ (lol w/the economy) to change some things. I don't want to go wild, just add a few mods for sound and response. Maybe later I'll add new headers etc at a second stage, but I think I could alsob swing adding a new cam.
6mustang8
  • Sep 28, 2008
Also, I'm looking at Tri-y's or hedman long tube headers for AT. Would I be limiting myself in the future with the hedman long tubes since they are for AT? Sounds like it.
D
D.Hearne
11,730
south louisiana
Sep 28, 2008
  • Sep 28, 2008
The auto trans headers will not work with a manual trans with the stock mechanical clutch linkage, if that's what you thinking of.
S-Car-Go
332
San Jose, CA
Sep 28, 2008
  • Sep 28, 2008
Personally I'd take a stock 289 with an OD trans (AOD or T5) with some gears over a warmed up 289, a C4 and stock open rear end.
If it were my car, I'd stick a T5 in there, run the exhaust (inc headers) around the new trans, then do the rear end, then worry about the motor.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
D
Headers - 302 in a 68
  • DAQ
  • Apr 4, 2024
1965 - 1973 Classic Mustangs -General/Talk- Apr 4, 2024
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
