68 idle problem
  • Thread starter Thread starter boots6868
  • Start date Start date Jun 29, 2010
boots6868
  • Jun 29, 2010
ok fellas, heres my trouble... in short the car starts up nicely runs smooth with a little low idle lope (modded cam) problem i got is when i drop it in drive ro reverse i gotta have left foot on brake and right feathering the gas to keep her running.
Now the long of it. Engine is a 5.0 explorer engine with gt40 p heads. 4bbl period fomoco intake with b-303 cam, carb is holley 600. dizzy has pertronix i with flamethrower coil (wired switched 12v).
i was running a 4100 autolite carb thought that could be my problem. so i sold that and went to the holley 600, im sure i got all my vacuum line double checked, im starting to wonder about the stock torque converter being compliant with my cam. timing is set at 10 btdc with vacuum line plugged. the car will start with the slightest bump of the key. and rev from idle to 4000 rpm without a stutter. but like i say drop her in drive and she darn nears dies even with the idle set at 900rpm. i would like to hear any ideas or experiences with higher stall converters if this worked for you or not. thanks
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jun 30, 2010
  • Jun 30, 2010
In park or neutral is your idle 900 ? I think you want it around 1300 in park/neutral for an auto.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
