68 Pop open gas cap question
littleneddy
Hey there, long time lurker, first time poster...
I have a '68 coupe with the deluxe pop-open gas cap, however under the cover there is no gas cap. As I understand it, there was originally a spring and a gas cap that would press against the filler.
Anyone know where I can get the spring and gas cap? Looking around, it looks like the only thing for sale is the entire assembly. Failing that, is there a small gas cap that I can screw on that will fit under the pop-open cover?
Thanks,
Ned
On my 67 with pop-open, the spring never sealed that well. I ordered a replacement assembly that came with the new spring attachment separate and a regular cap. I decided not to assemble the spring section and just use the regular cap under the pop-open lid. Now I won't leak gas on hard starts.
I have an original (though not to my car) and I have at times had to wire my pop open gas cap shut because it does just that...pop open. This is normally only at the track, but it has happened during regular driving too.
Get one of those cheapo twist ons from the local parts store, they're probably only $4.99 in the "fix-it" lineup (the red packages). They're fugly of course but they work, and in your case it will be hidden by the pop-open factory unit.
